Question about Emerson Televison & Video
Its Emerson Model LC320EM9B ManF 2006
Its turns on but turns right back off after about 30 seconds back to red
2 Suggested Answers
  • 608 Answers
SOURCE: I have an Emerson TV Model #LC320EM9B about 1
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
I have a Emerson model LF391EM4 flat screen that when turned ON shut itself off after apx 10 seconds. It has never done this before, what can I try to do?
REBOOT IT BUT HOLDING DOWN ON THE POWER AND TURN IT BACK BUT HOLFD IT DOWN FOR ABOUT TEN SECONDS AND THEN TURN IT BACK ON
Jan 09, 2017 | Emerson Televison & Video
My tv will not stay on.model lc320em9b. tv will only stay on for about 2 minutes then goes off.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 24, 2015 | Emerson LC320EM9 32 in. LCD HDTV
Solutions?
Hope this helps
Jun 10, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Trying to connect a surround sound system to my lc320em9b but no sound.
SORROUND SOUNDS SYSTEM ON TV DEPENDS ON THE TV STATION UV OPEN,U CAN HAVE IT IF UR WATCHING STATIONS HAVE SOUND SURROUNDS ON A PLAYER,W/ SOROUND
Feb 28, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Nov 30, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Emerson 32 inch lcd
i have your answer!!!!!!!!!!!!!!!!
use the PRODUCT WARRANTY call emerson and have it sent back, then your like oh wow it works like new( and it will be a new one) yay thank you so much guy on the net for telling me about the PRODUCT WARRANTY
Oct 21, 2008 | Emerson EWL3706 37 in. LCD Television
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Daylight saving time issues
I picked this up from the Emerson Website Read below before going to the link. Try thi link: and poke around the website http://www.fox-international.com/emerson/ Important Notice About Daylight Saving Time (DST) and Emerson SmartSet® Clocks and Clock Radios Congress recently passed a new Energy Bill which includes a provision to extend Daylight Savings Time. At the beginning of 2007, Daylight Savings time will begin on the second Sunday in March and end on the first Sunday in November. Because of this change your SmartSet® Clock or Clock Radio will need to be updated. In order to set your unit we will need the following information from you: 1. Model Number You can find your model number on the back or bottom of your unit. (Click here for an example) 2. Serial Number You can find your serial number on the back or bottom of your unit. (Click here for an example) Based on this information we can identify which setting is necessary to adjust your unit for compliance with day light savings. There are three possible groups your SmartSet® Clock or Clock Radio could fall into: Group One changes the time zone to a previous time zone. Group Two adjusts for the spring and fall settings. Group Three is already set for 2007 daylight savings compliance. Group identification begins with your serial number. The first three to four digits of the serial number represent the year and month of manufacture. (If your serial number begins with 0607, that would indicate July 2006, 506 would indicate June 2005.) Models manufactured before January 2006 (serial number 506, 512, etc.) will follow Group One settings. Models manufactured between January 2006 and July 2006 (serial number 0601, 0603, etc.) will follow Group Two settings. Models manufactured after July 2006 (serial numbers beginning with 0608) are Group Three and do not require any changes. If you believe you have a Group One model, please click here. If you believe you have a Group Two model, please click here. If you cannot determine which Group your model may be in, please call us at 1-800-526-7521.
Mar 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
