Question about Boating
Shinbisa air rifle 177, need pump seal
Break barrel, made in Japan, pump seal appear to be leather.
  • 2100 Answers
SOURCE: pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Posted on Feb 13, 2010
  • 2100 Answers
SOURCE: I Have a crossman .177 air rifle, that you have to
Some air gun problems are an easy fix, some require extensive presses and jigs to move springs around. Most are not to messed with. I know, I have tried my best to repair an air rifle or two and had to send them back to the company to get them fixed. And there is nothing I can't fix, I have a big machine shop, been gun smithing for years and couldn't fix a little air rifle. Check out this website, it might help you, or steer you in the right direction. ,,,,,,,
Posted on Mar 09, 2010
  • 2100 Answers
SOURCE: 397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
Posted on Apr 19, 2010
  • 2702 Answers
SOURCE: I have 2 Daisy air rifles. One is a very common
i cant help you with a canadian source but i can with a british one try..
T W CHAMBERS & Co,,,e.mail,,,uk
if this guy dont have what you need il eat my hat after you have done some thing nasty in it???
Posted on Jul 14, 2010
Testimonial: "Thanks for the UK source, I never thought of that ."
  • 79 Answers
SOURCE: Hi, I received a Crosman
Hit the top of the barrel with your hand. Don't be afraid to give it a good whack.
Posted on Jan 08, 2011
Can i but a new barrel how much
Bone Collector .177 and .22 cal special edition air rifles ... > Air Rifle
The "BONE COLLECTOR" .177 and .22 caliber air rifles. ... blast reducer integrated into a bull barrel, and utilize the advanced IGT (Inert Gas Technology).
images for Bone Collector .177 Caliber barrel
Nov 07, 2015 | Gamo Bone Collector .177 Caliber Hunting...
If you simple have the air go right thru each time you pump it, there is a little o-ring between barrel and the chamber, probably the one that needs replaced. Call Crosman and order by phone or go on-line.
Feb 11, 2013 | Crosman Recruit Multi-Pump .177 caliber...
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
Feb 18, 2011 | Crosman Phantom .177 Caliber Break Barrel...
Need a repair manual four a crossman 177 cal pump need to put it back together
found a picture how the trigger and springs set up worked all i needed was where one spring went.didnot find a manual on the web. thanks
Mar 10, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Pelet rifle won't fire
Feb 13, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Will not pump up in order to fire
open the pump handle and spray a little WD40 into the piston tube and let the gun stand **** down for an hour or so. close the handle and try again. It seems the piston sticks and then separates from the linkage in the pump handle.
Apr 03, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Air rifle?
Most rifles will hit whithin at least one inch across a normal back yard. You're quality is going to come from the manufacturer. CO2 and Air Pump is a personal choice, I have noticed no difference in performance, though some say CO2 is more reliable. Daisy is a classic manufacturer and has some modern, good weighted rifles that will shoot dependably. Anything with a Walther barrel or the Walther name is a good investment when it comes to rifles (not so much for pistols). Break barrel actions are prone to jam, be difficult to open once lead shavings build up, and pinch nastilly, and if you have a child or are a novice shooter yourself, a traditional action will help you learn proper habits early on. You really shouldnt spend 300$ for an Air Rifle, or even 200...Maybe even 100.
Mar 25, 2009 | Caliber Gamo USA Hunter Elite .177 Air...
Where can I purchase a Breach Seal for a Crosman Spring Air Rifle, Model C1K77? The Product # is C1K77-008. Also, Can I replace the worn out seal with a standard "O" ring (black) found in most hardware...
I don't know if you'll read this but I too Have a Crosman Phanton among other Crosman rifles. You can call Crosman at 1-800-7-AIRGUN for a free breech seal if your rifle is still in warranty (One Year) or e-mail me and I'll send you one at no charge. Don't worry I have several and don't have a problem with giving you one.
Mar 05, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Boating Logo
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
