Question about Ctm Health & Beauty
Ctm hs-580 batteries fully charged scooter moves but has not much power
2 Suggested Answers
luisnavarror
  • 3 Answers
SOURCE: intermitant drive power on my ctm hs 740 mobility scooter
The problem is going to be your motor. After extensive usage, the motor will give up internally and some times it will burn and melt the possitive/negative cables at its housing and it will give you issues with the batteries and the module.
Luis CTM: 909-590-1388
Posted on Feb 14, 2012
What is the weight on the batterys
Lead acid batteries are not light but generate copious amounts of relatively inexpensive cost. Our battery technology is at least 100 years old but....................
Nov 18, 2015 | CTM Homecare CTM HS-580 4-Wheel Power...
How heavy is a ctm hs 580
hi,
Total Weight with Batteries : 197.8 Lbs.
Regards
Rob
www.gewizrepairs.co.uk
Jul 12, 2015 | Ctm Health & Beauty
Ctm hs580
5 flash code indicates your brake. Check your free wheel lever and ensure it is in drive.
Aug 26, 2014 | Health & Beauty
Light is flashing 6 times
Hi,if the controller is a blue finned model called a Rhino, then the following applies...
6 OONAPU Out Of Neutral At Power Up. The throttle was not in the neutral position
when the scooter was turned on. The scooter does not drive.
• Return the throttle to neutral, turn the power off, and back on again.
• Throttle may need to be adjusted (see section 5.1.6).
• Check throttle wiring.
Regards
Rob
And please join me on Facebook https://www.facebook.com/gewizrepairs
May 10, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
Mar 30, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
Intermitant drive power on my ctm hs 740 mobility scooter
Oct 29, 2011 | Ctm HS-2800 Power Wheelchair
Health & Beauty Logo
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Dan Apthorp
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
