Question about Tablets & eReaders
The line runs across the kindle firelogobut won't turn on as soon as i remove the charger it turns off
3 Suggested Answers
  • 457 Answers
SOURCE: Kindle light is orange when
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Posted on Jul 23, 2011
Testimonial: "Nope, nothing. I tried plugging the usb into my laptop. The Kindle doesn't show up or it says no data/driver found."
mobil master
  • 14641 Answers
SOURCE: KINDLE WILL NOT TURN ON
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Oct 19, 2012
My kindle fire [new 2 mos. ago] has a green line around the opening page, and it will move to lock, camera, safe mode but nothing will open. I tried the kindle support - $5 +$49 for help?
Donno if this will help but these are the issues and how I somehow managed to clear most of them on my Kindle HD fire (7 inch); I got mine about 2011 I think.
Problems I've come across with HD Fire; Glitches, blinking screen, very slow or stopping to work, Very slow loading, Freezing program and final; 1/2 screen (the worst of it)
* Slow or frozen is usually cleared by turning off (or flipping cover closed if you have an on/off type of case.
* Glitchy loading; Try to turn off or remove apps you don't use or rarely use. Many run in the back ground and take up memory, speed, bandwidth, and battery power. Check on youtube for help with this as it can be clumbersome.
* White out, is a symptom of over heating (like in a hot car or at the beach in direct sun light.) this is scary as nothing works. Dead giveaway is that the Kindle if very hot! Remove from heat source and take it out of case. Leave it on a FIRE PROOF table top like stone or metal. Use a cookie tray if you have one. Caution! if the kindle was heating up by itself while charging then remove from charger! Check if it's the right charger or charge with a lower power unit (300-500 milliamps) but do this AFTER it cooled down. Don't use a fast charger! Heat and Battery charging are a bad combination and will damage your kindle. I'm still using mine afer ....7 years? yeah the 1/2 screen clears up after the charge gets below 80%. Donno why this happens. It might be the battery may be swelling during certain power levels. It reall does not like being charged to 100%.
* For the errors listed above the final solution (besides returning it to Amazon) is to do a complete power shut down or hard shut down which involves holding the on/off button down for at least 30 seconds. This is like a laptop hard reset. Turn it back on after a minute and it will slowly power back up. Oh, forgot; Don't let the Kindle ever get to the point that it crashes completely. Once you get the final 5 min low battery warning. PLUG it back in to charge! You run the risk of corrupting apps and data. Some may need re-install.
* Okay the very last resort; Check that you back up all data to your cloud drive. Many kindle apps will do this already (like Checkbook) But if you have documents that were created on the kindle and not sourced out then have it uploaded to your Kindle (Amazon) cloud. Check the kindle help line for more info. OKAY: Now go to your kindle:
1. Swipe from top - down for menu.
2. Swipe menu to left to get to (+) More...
3. On settings choose Device.
4. Choose Reset to Factory Defaults.
5. If you WROTE down your passwords and account #'s and have them handy then proceed with "yes" to continue.
If not the STOP! and cancel, get out of menu and go find all your account info:
- Wireless access password (yours)
- Amazon Account Name, User ID, Password.
- You will need to reload all your apps that you currently use. Don't load stuff that you rarely use as you can always load them later as they reside in you amazon cloud account. You should not need to repurchase them. (though I've had problems with apps that require a "Key" code as they don't always work and some require 'proof' that you already purchased them.
6. Reset and let it go through it's power up and new customer initial set up. You will be surprised at what you forgot, even after a month. Try 7 years and you won't remember a thing!
* I'm reluctant to perform a factory reset as all my game scores, past history, and other stuff gets lost. Once I waited 2 years before giving up. (+$70,000.00 on Vegas style Solitare)
*** NEVER EVER!!!!
***send the kindle through a Airport X-Ray machine! ***
*** this is what caused my 1/2 screen! It comes and
*** goes every few months. It's sporatic.
*** Seems to always want the wireless to be on as
*** once turned on it will clear the screen after the
*** battery drops between 65 to 35% charge.
*** I've been using my kindle like this for about 5 years
*** though I've switched to a 10 inch Android Phablet
*** now and found almost everything works once log
*** into Amazon. BUT you may find it cranky on
*** Amazon books as it won't reccognize my
*** Phablet. I still purchase books with my Kindle
*** which will automatically be available on
*** other devices as long as it's logged into
*** the same account.
Aloha, ukeboy57
PS; if you have two kindles or more and it's for the (adult) kids then think about keeping them on one account as anything you buy (books) will also be available to them and visa versa. Or if saparate then you can loan them the book or purchase it as a gift.
May 10, 2018 | Tablets & eReaders
Kindle fire
James, You have to make sure the Kindle is charged, try holding the button longer, maybe even up to a minute, hopefully that will do it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." You can also do a search on google for this issue, seems there is a lot of info. on this problem.
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
12 major Kindle Fire problems and how to fix them
My kindle won turn on Is it the battery Kindle Fire HD
HDX will not boot
Jun 19, 2016 | Amazon Kindle Fire HDX 7
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Reset Kindle Fire When it Won Turn on or Charge
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
Kindle fire stopped working/will not open
try pressing and holding the turn on button. if bit call customer service
Jan 31, 2015 | Amazon Kindle Fire HD
Won t turn on
Have you held the button in for ten seconds? Are you pushing it in correctly? Did you charge it? If the battery goes down it will not come on. Plug in the charger for awhile then try turning it on. If you spilled something on it you might have a problem. So many things we dont know. Try the charger first.
Sep 05, 2014 | Amazon Kindle Fire HD
My Kindle does not charge?
Try with another charger. If this not resolve the problem you have broken charging connector, charging line or mother board problem.
Aug 27, 2014 | Amazon Kindle Paperwhite
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Kindle will not turn on
The Kindle Fire will not turn on, correct? Let's try a hard reset.
Step 1: Unplug the device from the charger
Step 2: Press and hold the power button for 30 seconds
Step 3: Release the power button, then press and release the power button normally, the Kindle should wake up
Step 4: If the Kindle does not wake up, find an alternate charger or go down to Radio Shack or Staples and get a new charger
Step 5: Plug in the new Charger to the Kindle for 12 hours when done leave the Kindle plugged into the charger
Step 6: While the Kindle is plugged into the charger, press and hold the power button for 30 seconds. Let the Kindle charge for another hour.
Step 7: Pickup the Kindle, press and release the power button normally, the Kindle should now wake up.
Step 8: If the Kindle does not respond, contact Amazon for a replacememnt
Apr 21, 2013 | Amazon Kindle Fire HD
Tablets & eReaders Logo
48 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
