Question about The Computers & Internet
The range of my HelloBaby monitor has suddenly been reduced by 50%. Nothing in my household has changed, how can I get the extended range that I used to have?>
    Top Expert:
  • The Master
  • 46,605 Answers
Try new batteries in both units
Posted on May 08, 2017
How to extend range
Difficult one to answer. You cannot adjust anything internal to the router to extend the wireless broadcast range. however, there are a few things you can try to make the most of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. The model you specify has the 3x3 MIMO antenna array so should give you a decent range, at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Oct 18, 2013 | Cisco Linksys Wireless Router EA4500...
When the faucet is turned on outside there is a banging sound almost like a hammer. Under the sink in the closet bathroom the pipes are even shaking when this banging is happening. What is going on?
This is an occurance called "Water Hammer" or Hydraulic Shock, which is caused by a sudden change in fluid (water) pressure. You can try a few things, but ulness you're handy and confident in your skills, you should consult a Licensed Plumber for repair. Either way, you should fix the problem as soon as you can, As over time, this can cause damage to the pipes. There are "screw in" or "solder in" air chambers designed specifically to eliminate this problem, by allowing an area of expansion. You can try and reduce the household water pressure Secure the waterpipes with clamps to the wall or reduce movement. For the immediate, short term solution, try turning the faucet off slower to reduce the sudden pressure change.
Mar 08, 2011 | Home
Input signal out of range......my problem...hp w1707
your video card setting may not be compatible with your monitor's capability. you may need to reduce the screen resolution. you need to boot up on safe mode to change this or use another monitor for a while and try to adjust the screen resolution.
Oct 07, 2010 | HP W1707 LCD Monitor
I have a lifestyle 28 and for some time now the range within the remote can be used has reduced a lot, as a matter of fact, sometimes even as short as 4 meters away. I also have noticed that for some...
try t use a remote extender with multiple sensor wich can be use to extend the range of your remote or try chage the battery of your remote....
Sep 30, 2010 | Bose Lifestyle 28 System
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
The the width of the picture on my Monitor is reduced.
hi
you may click the right button of your mouse and go to the properties.From there you can adjust the screen resolution.
Jul 01, 2009 | Computers & Internet
Extended monitor wont extend
can you now see 2 monitor properties i.e. 1 & 2... then identify running monitor ... if it is 1 then select 2 in properties and set it again to be used as extended desktop... open any application and pull or drag it holding it from title bar to the extended desktop....
May 31, 2009 | Acer AL2016W 20" LCD Monitor
Rande extender issues for ps3
Both your neighbor's router and your range extender must be set to use exactly the same SSID, encryption key and FIXED channel assigment.
Dec 09, 2008 | D-Link AirPlus G Wireless Range Extender...
LcD say "video Out of range
Hey...
It's mean your monitor not support to this ranges... need to reduced the resolution to mfg. settings...
Nov 29, 2008 | ASUS LCD Monitor
Computers & Internet Logo
Top The Computers & Internet Experts
Darren  Means
Darren Means
d3yavu3
kimblebear
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
