Question about Sony Televison & Video
I do have Sony XBR-65X750D tv, got the picture and menu sounds but no sound from the hdmi connections
  • 6 Answers
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Posted on Dec 29, 2007
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Posted on Jan 08, 2009
  • 4234 Answers
SOURCE: TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Posted on Feb 10, 2009
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
  • 4 Answers
SOURCE: Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Posted on Feb 17, 2011
All picture and no sound
simply unplug--then replug--your HDMI cable. Or also go into the audio setup menu and reapply the "automatic" setting for HDMI to get the sound to work. I don't know if Sony can do anything about this or not in a firmware upgrade, but what it can do is try to simplify the labeling on some of the sound settings.
Let me know
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
The picture is black
If you're using components or audio video cable make sure there properly attached to the device and the TV......if you're using HDMI cords in most cases you probably have the wrong resolution set on the TV or the devise.
Mar 21, 2014 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I recently bough a used 40in sony trinitron xbr. i have the DVI to HDMI cable but wether its my laptop or xbox the sound wont come through the tv at all. any suggestions?
Check the audio cable it might not been connected securely.
Could also be missing.
Even with the HDMI you may still needs it ( DVI is for video only).
DVI means Digital Video Interface.
Sep 26, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Bravia KDL 52Z5100 - no sound only picture. HDMi cable works fine with another TV, so no probs with cable TV.
A short fix is to unplug the hdmi cable and shut down the tv compleetly, then get the tv on and plug it in, the tv see the new connection and reset the value's for sound
Feb 15, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Open Questions:
Televison & Video Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
