Question about Canon Office Equipment & Supplies
How to place the paper to scan on a Canon Mx922 and send to my Pc
Mx922 thinks it's out of paper when tray is full
out paper problems are usually caused by a worn pickup roller for a replacement solution on a pickup roller
Mar 19, 2017 | Canon Pixma MX922
I am researching the Canon MX922. Will it print on cardstock and if so what weight? Also, is it compatible with Vista.
If you wantCanon Printer Customer Service Phone Number, then you can contact with us Canon Printer Tech Support Phone Number#1877-778-8@9@6@9.We are always here with tech team for your help. For further information Click:
Aug 15, 2016 | Canon Pixma MX922
Where do I load photo paper to print photos?
There are two drawers. For paper you put your fingers downwards and pull out the paper drawer. For photo paper the drawer is above it, so curl your fingers upwards in the same place and pull.
Based on my MG7120.
Jan 08, 2016 | Canon PIXMA MX922 Wireless All-in-One...
Color photos are really off color.
Hi George!
Are using Genuine Canon Ink & Paper?
Here are some links to your printer troubleshooting videos etc.
Canon Support Drivers PIXMA MX922
Jun 30, 2015 | Canon Pixma MX922
How do I clear a paper jam Chk here
Feb 03, 2015 | Canon Pixma MX922
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
When I send a fax there is a thin black line from the top of the page to the bottom. Is there a way to make this line disappear?
if you scan documents through ADF (auto document feeder), open the scanner lid and check / clean the thin strip of glass on left of the main scanner panel. Use windex or similar window cleaner.
good luck
Nov 21, 2014 | Canon Pixma MX922
Set the pc to start scanning
After re installing software I still got the same message.
So I went into the menu on the MX922. Then to Setup. Device settings. Then reset settings. Then Reset ALL. Works fine again.
Jan 04, 2014 | Canon Pixma MX922
37 people viewed this question
old marine
old marine
