No picture , grey screen with v3.02.0 on rotating left to right ?
3 Suggested Answers
  • 213 Answers
SOURCE: grey stripes down the left and right side
TACK IT OUT OF 1080I CHANG YOUR FORMAT ON YOUR TV
READ YOUR MANUAL WILL HELP YOU OUT.
THIS SHOUD HELP YOU OUT.
Posted on Dec 17, 2007
  • 979 Answers
SOURCE: picture has rotated to the left
Hello Arvell, Hi, try pressing CTRL+ALT+up arrow, see if the picture goes to normal.
Posted on May 21, 2010
The picture suddenly rotated 45 degrees to the left
you need click on your monitor options down on your sys tray in the right hand corner, right click and there will be your options on rotating your screen
Sep 25, 2014 | Acer 22" X223w LCD Monitor
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My screen is sideways and i cant get it back to normal
Right cllick on your desktop and choose personalize. At the bottom of the left panel click display and then click change display settings. Click on the orientation drop down menu and change it to landscape.
Mar 14, 2012 | Dell Latitude E6500 Laptop
What are the speakers wire colors on a pioneer car stereo?
fr left + white
fr left - white/black
fr right + grey
fr right - grey/black
rear left + green
rear left - green/black
rear right + purple
rear right - purple/black
hope this helps thumbs up pls
Aug 11, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Picture has rotated to the left
May 21, 2010 | ViewSonic VX1935wm LCD Monitor
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
The picture on the monitor flip 180 degrees how do I flip it back
Operating system of PC?
What brand of video card?
right click on empty part of screen.
left click on properties.
left click on settings.
left click on advanced.
look for the video card tab and left click on it.
left click on Start the "#####" (made of videocard) control panel.
Look in left hand panel for rotate display.
left click rotate display and there should be options to rotate display...
May 04, 2009 | Star Logic 17" LCD Monitor
Display screen upside down
It's broken wires to a switch inside the rotating mechanism. If you take the screws off of the screen and the rotating mechanism and remove the grey plastic covers you'll see a black switch inside a white plastic mounting that is anchored around the bundle of black wires going to the screen.
You'll be able to see the metal tab that rotates down to activate the switch when you swivel the screen (do this carefully with the covers off so you don't wreck the screen by asserting too much stress on it).
If you know someone that can solder tiny stuff, take it to them. It doesn't matter which wire goes to which terminal on the switch. You should see two broken wires in the black bundle - those are the ones that need to get reconnected to the switch. I used transformer wire to fix mine, as the insulation on transformer wire is painted on (and will need to be removed from the ends with a small file) instead of having plastic/rubber insulation that can melt when soldering.
Once the wires are reconnected, insulate them using liquid electrical tape, then put the wires gently back into the bundle, and make sure that the stress points don't land right on your solder connections. After that you should be good to go.
It's not a job for someone who hasn't soldered before... better left to someone with steady hands and the necessary equipment.
Hope that helps!
May 15, 2008 | Canon PowerShot S2 IS Digital Camera
Grey stripes down the left and right side
Dec 17, 2007 | RCA D52W19 52" Rear Projection Television
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
