Question about The Office Equipment & Supplies
I have an older the Print Shop which I purchased in 2004. I use to print cards but haven't done this for a few years. I went to use it and it doesn't work. How can I solve this problem?
    Top Expert:
  • The Master
  • 39,229 Answers
Your old software probably is incompatible with newer systems.
Posted on May 08, 2017
The card have a faint line across after printed. I have cleaned the printer but no luck.
Usually a faint, light line running the full length of the card is indicative of either a need for cleaning, or a problem with the print-head itself. As you've already cleaned the print-head, we can rule that out.
We occasionally see the print-head get scratched, causing this issue. Or, there are occasional (but rare) issues with the electronic components of the print-head. There is not a fix for either, other than to replace the print-head.
Some clients will redesign their badge templates to ensure there is no printing required in the area where the print-head is failed or failing, allowing them to get by without replacement.
As the Pebble line was discontinued in 2012, and it carried only a 2-year warranty, it is unlikely your machine is covered, unless purchased new in April 2013 or later, AND that all required printer cleanings (every 1000 cards) have been done, per Evolis requirements.
Safe-Card ID Services
http://www.safecardid.com/
Mar 27, 2015 | Evolis Pebble Color Card Printer
Drum end soon brother mfc 7320 printer usb002
My Brother MFC 7420 said drum end soon, so I ordered a new drum. Then I waited for something to go wrong before I replaced it. Basically I was looking for a deterioration in print quality. I waited and waited. I think it was over 3 years. I replaced the toner a few times. While the print quality never really went done, the frequency of other problems finally shot up. When I replaced the drum the problems went away. My advice -- ignore the warning unless you have other problems.
Dec 08, 2013 | Brother MFC 7420 All-In-One Laser Printer
I lost my pics on file on the camera after i hit "format" "yes" help!
If the pictures were on a memory card and you haven't done anything to the card since formatting it, you should be able to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program suitable for your computer and operating system. Put the card into a card reader attached to your computer and run the program.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sep 28, 2012 | Video Cameras
What GB memory card does work in a C310 digital camera. My printer dock does not work anymore except to charge my camera and I thought I could get a memory card and print the few pictures I take at a...
The C310 will accept SD cards up to 2GB in size and SDHC cards up to 32 GB. 1GB SD cards are getting hard to find, but 2GB cards should work just as well.
BTW, FixYa doesn't have an online store.
Jun 21, 2011 | Kodak EasyShare C310 Digital Camera
I purchase a print head from Epson. I put it on by myself, did a power cleaning. But two inks doesn?t print out while I am doing print head testing prints. And then i did some head cleaning by using the...
If you go back to the utility, are you able to confirm that the ink levels for all cartridges are not empty? If so, which are the two colours that do not print?
Jul 02, 2009 | Office Equipment & Supplies
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Bad print head
HP C5010DN(Black) and C5011DN(color) are the part numbers. I am surprised staples does not carry them, but you should call around to local stores that sell printers. In Canada I use Future Shop or Best Buy.
Dec 05, 2008 | HP OfficeJet d145 InkJet Printer
My DTC 400 bladge printer jams a lot.
The DTC400 has an o ring that drives the card feed rollers. Fargo has had a problem on older DTC400 printers with the o ring stretched or broke. This causes irregular feed roller issues, ribbon breakage or misalignment of print registration.
It is recommended to do a ribbon sensor calibration. This can be done through your print driver using the directions in this link.
Your DTC400 came with a two year manufacturer warranty. Contact Fargo Technical Support at 800-459-5636.
For more information about id card printer systems, visit our website at www.safecardid.com
Nov 13, 2008 | Fargo Office Equipment & Supplies
Black won't print!!
Hi denzirelli, Apparently several reviews of this printer say it is known for poor print quality when dealing with graphics AND the tubes can become blocked. As far as troubleshooting goes if you haven?t done so already purchase a new set of official Brother ink jet cartridges, black and color. The newer ink jets are a lot smarter and remember the last couple of cartridge serial numbers. If that doesn?t work then try running the nozzle cleaning utility a couple of times. If that fails call the Brother and let them walk you through the troubleshooting process. I don?t suggest you lie, just don't volunteer the fact that you were evil and tried to deprive them of their profit. Worst case they won?t do a warrantee replacement, best case is you?ll have a working printer. If you don?t want to pursue the above option or if tech support won?t help then we?re back to troubleshooting again, when you say it doesn?t print black does that mean colors do print? If that?s the case then I suspect the black tube or the nozzles are blocked. From what I?ve read it?s a little bit of a pain to remove the print head but the key is not to disconnect the tubes. Remove the print head and the cartridge container as a unit. The ribbon cables have to be unplugged from the circuit board. Disconnect the belt and you should be able to take the print head out and clean it. Let us know how it turns out and don?t forget to rate the posting.
Jan 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
