Question about Cooktops
Brilcon ceramic cooktop. How do you turn it on?
I have found the answer thank you to all those that looked at my post. ????
catriver
  • 878 Answers
SOURCE: Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Posted on Feb 26, 2007
jyackle5
  • 8197 Answers
SOURCE: Whirlpool Gold ceramic cooktop removal.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
Posted on Dec 16, 2008
jyackle5
  • 8197 Answers
SOURCE: I need to remove my Whirlpool Gold ceramic cooktop.
  • 111 Answers
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Posted on Dec 19, 2008
  • 949 Answers
SOURCE: My ceramic cooktop has cracked. Can I just order
You can get the main glass top, the part number is WB62T10525 and it runs just under $300.00, it is shown here as 51. It does take a bit of dis assembly to install it.
Posted on May 05, 2010
How do you clean a Brilcon ceramic electric cooktop
You can buy ceramic cooktop cleaner
Oct 22, 2017 | Cooktops
Looking for manual for Domain ceramic cooktop CER90-T
Go to RepairClinic.com you can find the answer there.
Sep 20, 2014 | Cooktops
316065306how many watts to run this range
Hello friend, thank you for your post!
I understand that you are searching for the wattage on your Frigidaire range. In order to provide you more information I would need to have your model number. You can locate your serial tag (which lists your model number) on the outside of your cooktop base possibly on the edge or bottom under the unit. Once I have that information I can further assist you. I look forward to your response. -Matt
Aug 19, 2014 | Frigidaire 30 in. Electric Ceramic-Glass...
UNLOCK THE LOCK OF CHILDREN IN CERAMIC
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | AEG HK955070CB 41 in. Electric Cooktop
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Dec 14, 2008 | Cooktops
Dec 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
93 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
