Question about Kenwood Car Audio & Video
Instructions on how to connect Bluetooth to a kenwood model DNX5180
Bluetooth LG to my Kenwood
you need to make sure both the Kenwood and the LG have bluetooth enabled. Then you pair the two using the pairing function in the LG. Hopefully this should enable you to play music from LG on Kenwood and also receive calls. As you have not provided any model numbers it is difficult to say whether the phone and your Kenwood audio systems are compatible.
Best to go to this website and select the correct model numbers and find out which features in your LG phone will work with your kenwood.
Bluetooth Compatibility List Kenwood
Aug 07, 2014 | Car Audio & Video
Stopped working after trying to fix it
It could be one of the metal sides touching the board or any other electrical part. Try to unflatten a it a little or try to making avoid this part to touch each other. Good luck!
Jun 13, 2013 | Kenwood DNX5180 Car Video Player
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
We just installed the Kenwood KDC-X692 in our 1993 BMW 740il. The tuner works, but the CD has no sound and the AUX doesn't work either. I'm also confused on the bluetooth ready but lack of instructions...
i'm assuming you are going through an amplifier. if so it sounds like you are using the blue wire instead of the blue/white wire to turn the amplifier on. i can't really help you with the bluetooth though.
Jan 05, 2011 | Kenwood KDC-X692 Car CD/ MP3 Player
KDC-W7537U model number Code for bluetooth
most of the default codes are 1234, 0000, 1111 unless changed by the user. if this doesn't work, you can always do a hard rest of your radio by pressing the small pin hole button on the face of the radio.
hope this helps
Oct 04, 2009 | Kenwood KDC-W7537U CD Player
How do i set up my bluetooth for my kenwood kvt-512. im trying to find the bluetooth app in the settings
The Kenwood 512 works with the Kenwood KCE-BT200 module. You need to have this box plugged into the main unit to work. If not, then Bluetooth will not be available. When you do have it connected, use your cellular phone to initiate the connection. when prompted on your phone for a passcode, it will be 0000. After successfully pairing your phone to the unit, you can access the telephone menu by holding the "FNC" key on the front of the Kenwood or pressing "TEL" from the source screen.
Aug 11, 2008 | Kenwood Car Audio & Video
Kca bt100 bluetooth
Here is a link to a list for your bluetooth:
Aug 30, 2007 | Kenwood KCA-BT100 Wireless Headset
Car Audio & Video Logo
57 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
