Question about Garden
How much oil goes in a bolens 15.5 engine - Garden
  • 534 Answers
48 oz.
Posted on May 08, 2017
What type of oil do I put in my bolens front time tiller 332
10w-30 for engine oil will be OK.
Synthetic oil is a good choice.
The gearbox for the tines would need to be a heavy wt. lube.
85 or 90 weight.
Sep 16, 2017 | Garden
Bolens 15.5 hp riding mower. How can I find the motor numbers?
Because of the engine size you give I would guess it is a Bolens made by MTD, there should be a tractor model tag under seat that if you enter that info into google or it will tell you what model engine it was made with.
Mar 10, 2016 | Garden
I have a bolen snow blower with a 208cc engine that runs for 5 minutes then quits seems to lose compresion
you may want to try and see if your cylinder walls are scratched when it loses compression try using som oil in the cylinder and see if the compression comes back up. if so then you may have a scratch cylinder. if compression does not come up then look at the valves to see if they are seating right. if not then you may have to do a valve job.
Jan 26, 2015 | Bolens 158 cc 24" Front-Tine Tiller CARB...
Bolens push mower
it could be on the side of engine are on the bottom of engine
Aug 18, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Bolens cultivator model BL425 engine will not start
I would make sure that you have the proper gas/oil ratio mixed first. If that is ok then I would have the filter changed. If that doesn't solve the problem then you should take it in to have the carburetor serviced.
Jul 04, 2014 | Bolens 25cc 2-Cycle Gas Cultivator BL425
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
15.5 hp B&S engine on Bolens 42 in. mower will not
First off drain out oil and replace with new.
Second, remove carb, take off bowl on the bottom and remove the float, you need to do this because dirt has got under the needle and caused it to stick open allowing fuel to flow into your oil sump, once removed blow out gently, or wash with clean fuel and rebuild.
Once you have done the above, remove the spark plug and pull engine over about 15 times to blow out all oil and fuel that is sat in the top end of engine. Refit the plug and attempt to start her.
If the engine still wont turn over adjust valve clearances to 7thou, this will make the auto decompresser work more efficientley. to adjust the clearances, set piston to top dead center with both valves closed, back piston off 5mm ( guage this by putting a thin screw driver down the plug hole to touch the top of the piston, then turn top of fly wheel by hand untill screw driver moves in to engine by 5mm). check gaps on valves and reset to 7thou.
Valves are located under silver cover on the front of the engine next to exhaust pipe from cylinder head. The cover is located by 4 bolts, one in each corner.
Hope this helps,
Doc Scott
Jun 22, 2011 | Mtd Garden
What is gas oil ratio mix for bolens trimmer model bl100
50:1 here is a website that has parts list and threads for common problems, Hope it helps Tim:
May 10, 2011 | Mtd Garden
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
