Question about Refrigerators
French door frig with bottom freezer, freezer is not freezing, frig is not making ice and frig has started to warm up?
  • 534 Answers
Check for coolant.
Posted on May 08, 2017
My water will not come out of the water despenser
start by checking the solenoid that supplies the dispenser to see if it is burned out. It is usually located in the back lower part of frig where the water inlet line hooks to. There are usually 2 solenoids.... the ice maker and the dispenser. Unplug the frig before testing these. The resistance across the ice maker and dispenser are usually the same. If the dispenser solenoid is "open" on the ohm meter then the whole water supply valve needs replaced. Another problem with some units where the dispenser is on the FREEZER side...the lines behind the door will freeze.
Dec 28, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I got a new french door frig and it wont make ice CUBES. It makes ice and even though the indicator says cubed ice, it comes out crushed. Is there a way to fix this easily. Otherwise i like the frig very...
Try removing the ice bucket and ensure that there is no obstruction (ice cubes stuck inside of metal blades). If no obstruction, then your problem may be in the electronic dispenser control board (if applicable) that distinguishes between cubed and crushed ice. If it appears that the problem is the board, then contact an appliance service company.
Feb 10, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice dumps into the drawer but, sticks to the dispenser coil
The heater on the bottom of the ice maker is probable not comming on and warming the ice so it can be dumped. Some icemakers are rebuildable and you can replace the element, some arent.
May 12, 2009 | Maytag MFI2266AES Stainless Steel Bottom...
Ice maker wont make ice
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Magtag french door with water and ice despenser door with auto defrost keeps freezing up.
You have a defrost system problem related to the timing device, heaters, or defrost thermostat. Coils for the freezer are inside the back wall and defrosting the surface does not get ice out of coils.
it will not get any better until you have it serviced. This is not normally a project for a do-it your selfer.
May 28, 2008 | Refrigerators
No water and ice cubes
Check the water valves in back of frig. and see if working.. make sure you got a water supply valves may be plugged
Oct 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
Aug 27, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
