Question about Refrigerators
The Water is frozen at the back of freezer - model E402B - is there a evaperation pan under the fridge?
    Scholar:
    New Friend:
  • 69 Answers
Coil freezing is often a symptom of low freon. You might have a pin hole leak, and it's not a DIY job.
Most all refrigerators have a condensation pan, if not you would have noticed a small river, or a rotting floor.
Posted on May 08, 2017
My Maytag refrigerator is leaking water from under it. Model MFI2569VEM
Just how old your fridge is I don' t know. But is your defrost timer working on your freezer. It should defrost at least once a day. You may want to check out the drain on the bottom of the fridge also. It may be partly clogged up. Then newer models have the coils go over the pan to help evaperate the water.
Aug 05, 2012 | Maytag Refrigerators
There was standing water in the bottom of my Roper refrigerator under the crisper drawers. The drain pan under the fridge was dry. I cleaned up the water and vaccumed under the bottom of the fridge. ...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Jul 31, 2011 | Refrigerators
My model number 2811 has ice build up on the right hand side of the freezer. the service manuals indicate i need to pull the "cal rod heater down to make contact with the evaporator assembly and silicone...
Diagrams here : http://www.searspartsdirect.com/partsdirect/part-model/Sub-zero-Parts/Refrigerator-Parts/Model-2811/3054/0161000?searchedModel=2811&blt=05
These are the best I can Do with the Diagrams but I can explane what is going on, and possible soloutions.
Your defrost drain is mostlikeley frozen. This is located on the right hand side, just inside the metal cover. When you remove the meteal cover (((evaperator cover or water pan))) you will see the hole on the right.
Since this is cloged then the water stays in the cover or pan and freezes after the defost cycle.
after you remove the cover you will see the evaperator (( aluminum tubing with fins))) and the heater ((( Black Rod )))
When your machine gose into defrost about every 8 hrs, this heater melts the ice off the evaperator((( Hence Frost Free ))) and the water goest into the (((( evaperator cover or pan ))) and flows to the defrost drain hole to a pan under the machine.
They make a after market heater for the drain... it is a pain to install.
First I would try to defrost the drain by poring war water down it and verifying it goes into the pan at the bottome of the machine.
When your done you will need to silicone around the (((cover / pan))) where it covers the defrost drain hole.
Good Luck
Don
Mr Fix it
Sep 08, 2010 | Sub-Zero Freezers
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water on floor probably from cloged line leading to evaperation p
Look under the freezer bottom drawer for ice.
If ice is there your defrost drain line is frozen closed.
It is located on the back wall of the freezer down low.
Turn off the fridge. Use a hair dryer to melt the ice at the drain hole.
The ice under the drawer can be broken with a hammer and removed.
Mar 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
GE TCS18PADBLBS Freezer
if the drain line is frozen or clogged then you have to remove the back freezer panel and with a hair dryer at the bttom of the evaperator coil thaw the ice that is built up in the evaperator pan ouce you have it thawed you can pour water into the evaperator pan and it will run into the drainpan if you pour water into the pan and it does not run into the pan keep thawing
Apr 24, 2008 | Refrigerators
Fridge problem
you have a defrostion issue reed to remove the back panel in the freezer behind this panel is the evaperator coil needs to be melted down because it is full of ice and frost, ahair drier will work well,put several towells down under the bottom of the evaperator to catch water runoff, after defrosting the coil inspect the defrost heater or heaters some of these can have one or two heaters the heaters are located behind metal gaurds in the evaperator if either of the heaters are bad (both)need to be replaced, if they show good then bad defrost timer or bad defrost termination thermastat wiring diagram behind frount bottom grill
Apr 12, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
