Question about kawasaki Garden
I have a Kawasaki TH34 and when I increase the speed, the engine went off. Any remedy?
I have a 1999 kawasaki zx7r ninja i installed led front turn signals and the only way they will work is if i rev the engine can anyone help
When you rev the engine, the alternator voltage increases. I think that the LED bulb does not light up, do to not enough voltage at lower rpm's or idle speed. Buy some LED bulbs that are rated for the correct voltage. There is a minimum voltage requirement before the LED can turn on. If you have the correct voltage LED bulbs, then there is not enough current, in hundreds of milliamperes, until you rev the engine.
Jun 07, 2014 | kawasaki Motorcycles
Engine cuts out when requiring boost
check Fuel pressure regulator by disconnecting the vacuum hose. Didn't say what year you have, yet the timing belt can also cause this as I had similar problems on an 87 and the belts were loose and floppy causing erratic firing/idling. A little easy trick to check timing belts without taking any parts off to get at timing belts, is (and no one knows about this one, hee) with a timing light!
Apr 20, 2013 | 1997 Subaru Legacy
Engine cuts out when asking it to boost up
Hi, Without knowing vehicle name or year I must state this is for petrol models, your coil needs renewing, Derv you have air coming into the fuel system. Please leave me feedback, Malcolm Campbell.
Sep 23, 2017 | 1997 Subaru Legacy
I am having bajaj es125 : engine RPM increases when pressing clucth while coming to lower gear & not remaining at idle tuning
Hi, Vrishali and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have nice a day.
Manual Kawasaki Bajaj Wind 125 Documents
Jan 11, 2013 | 2006 Bajaj Wind 125
John Deere 17 horsepower Kawasaki engine won't run WOT when blades are engaded
swap the coil with the other side and see if that plug gets sooty instead of the one that has been
May 27, 2012 | Garden
Kawasaki brush cutter th34, clutch removal. There are two hex headed bolts holding the clutch mechanism into place. I was able to loosen both bolts but then after maybe 2 or 3 anticlockwise turns both...
Please use lots of care if you use the Internet to hunt for your repair manual!
These clowns CLAIM to have one for your TH34 but you MUST REGISTER to get it...suddenly MALWAREBYTES PRO started flashing 'alerts' about attempts to install a VIRUS on my system ~ NOT good!
The CLAIM to have MANY PAGES of desirable manuals to download from Harley s to whatever... Do NOT even TRY to download any:
monlongboardelectrique.com
AKA
monlongboardelectrique.com =
107.154.168.213 and 107.154.234.213
Dec 25, 2017 | kawasaki Garden
Hi there i have a ''92/93 model zzr400 kawasaki and it starts fine but needs throttle or it dies on me then i have to restart it i have to keep revs up to stop this , also after awhileriding it the temp...
Increase your idle speed at the fuel/air intake manifold. There should be a screw to allow for this adjustment. If that fails the engine timing may be off and should vbe reset to stabilize idle speed.
Mar 17, 2010 | 1992 kawasaki ZZR 400
How many turns out should mixture screw be
start with one full turn then move a quarter turn listen to engine revs will increase u might have to turn down the idle speed keep doing this till the engine speed stops increasing.take it arun then check colour of spark plugs they should be browny gray
Jul 13, 2009 | 1992 kawasaki ZZR 400
How to increase speed?
You can bore out the barrel to take a bigger piston or swap barrels from a 110 or 125. I know the 110 barrel can be taken out to take a Kawasaki 150 piston. This will need a new CDI and best to modify the exhaust too (more free flowing). I've done this with my Honda C70 and gone up to a wave 125 piston. the only thing holding me back is the 3 speed gear box but I have changed the sprockets to give higher cruising speeds.
You will need a bigger carb. Honda Dash Carb is just spot on. Its a Keihin and get an original (with the heavy plunger) not a cheap fake. They can stick open causing problems!
Jan 24, 2009 | 2005 Honda NF 100 Wave
Garden Logo
26 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
