Kelvinator split system does not always respond to remote. Works OK when manual switch is used. Remote batteries OK and info in remote window OK.
    Sergeant:
  • 197 Answers
Just put in new batteries anyway.... clean sensor on remote and receiving sensor on system see how you go... you could also have a faulty remote
Posted on May 08, 2017
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
The unit is a Kelvinator Air Con unit - Model #KSR25F-01. The unit will turn on manually but not from the remote. The remote has new batteries, but will not start the unit. The only button that the unit...
take the remote and put it in front of your cell phone.turn on the camera of your phone and push the buttons of the remote.if you see a light in your phone the remote is ok and then the eye of the pc board(is a small plate)has problem.
Dec 06, 2010 | Heating & Cooling
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different...
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Jul 14, 2009 | Electrolux Heating & Cooling
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Oct 16, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
