Question about Dishwashers
Hi my dishwasher has no power. There was a lot of water in the base which I have dried out. The model is DW60CDW2and the product number is 80539QU60610
    Scholar:
    New Friend:
  • 69 Answers
Did you check the breaker? How about the socket where it's plugged in?
After that it could be the pump motor, a bad switch, most of which are not DIY.
Remember Occam's razor.
Posted on May 08, 2017
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch Dishwasher drain mechanism starts itself a few hours after a completed cycle and won't stop. I reset the dishwasher, but it remains unusable for a few days. If I turn on the dishwasher, th
this could mean there is water leak and it collects at the base of the dishwasher leading to moisture detection circuit tripping. when you leave it for a few days the water dries up and trip is removed. check door seals for leak most likely at the base of the door. turn power off when working on dishwasher.
Jul 18, 2012 | Bosch Dishwashers
Miele Icognito G683 SCVI Plus. Residual water seems to be standing under the base guard and lots of moisture remains in the dishwasher?
Many dishwashers intentionally leave a bit of water in them to keep the seals from drying out...
if there is more there now then ther used to be then check this out...
Dishwasher Problems - Water will not drain out
heatman101
Jan 21, 2011 | Miele 24 in. Incognito G863 SCVi Built-In...
F1 code how to fix and re-set
Is this happening with both drawers or just one.
You have water leaking into the base of the dishwasher under the drawer.
Most likely the drawer seal is leaking.
The flood switch is located at the base of the dishwasher and this needs to be dried.
Turn power off and take the bottom drawer out. Dry base with towels and hair dryer. Turn power back on without putting the drawer back.
Run top drawer to see if any water is leaking.
Water leaks can be due to faulty seal or drain hoses cracked.
Hope you are able to fix it.
Sep 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Need a service person. Machine reads F1 and must unplug to stop it from running
Sep 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is brand new and is not drying the dishes!!! they are still wet. the model number is she55mi 2uc/60
If you are using a quick cycle there is not a dry cycle included due to the short wash. Ensure you use rinse aid even if you are using a product that includes it, as this assists the drying cycle by breaking the surface tension of the water and allowing less water to 'stick' to the load. Check that you have the machine set to the use the rinse aid and that the intensive dry is on. This can be done by following the instructions in your manual.
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying time for improved drying.
This option is only for units with a display. If your unit has a display window, please follow the instructions below.
NOTE: The unit must be powered OFF before activating.
To activate:
Press and hold the left "Cancel Reset" button, then • press and hold the ON/OFF button.
The model number I think should read SHE55M12UC/60.
I hope this helps.
When the LED display window indicates a "0" or "1" • release both buttons.
To activate extra dry heat, press the left "Cancel Reset" • button until the display indicates "1".
To disable extra dry heat, press the left "Cancel Reset" • button until the display indicates "0".
Press the ON/OFF button to save the setting.
Jul 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Jun 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch shx33a issues
sounds like the float is up and unit is in drain mode.if its only humming that is the problem. there is water in. the base.take off side panel and reach in the base with something to dry the bas out. normally this is caused by a leaking hose. if this doesnt fix problem post the question follow up. thanks
Nov 21, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Dishwashers Logo
Top Dishwashers Experts
