Split system only responding to remote intermittently. Batteries OK
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
  • 7 Answers
SOURCE: Remote Problems
you dont leve the remote in the sun do you? could be an issue
Posted on Jan 25, 2008
notsomot
  • 67 Answers
SOURCE: a/c remote working but system wont respond
Heya Allhart?
How did you check the remote? Did you check the remote via viewing it on a LCD screen? If the remote is working than you need a new receiver PCB for your air con and would contact Sanyo to see if it is under warranty or for them to get someone out to veiw.
Hope this helps
Posted on Jan 08, 2009
hvac1960
  • 2133 Answers
SOURCE: nec split system air con
Remove batteries and replace with new batteries and restart. If still problem, unplug DC wire to indoor display sensor and plug it after a minute. Now try with your remote. If still problem, try with another remote. If no result, PCB receiving sensor defective. Replace display sensor or PCB
Posted on Jan 27, 2011
dunnbiker
  • 8546 Answers
SOURCE: The remote functions intermittently. have
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Apr 23, 2011
Kelvinator split system does not always respond to remote. Works OK when manual switch is used. Remote batteries OK and info in remote window OK.
Just put in new batteries anyway.... clean sensor on remote and receiving sensor on system see how you go... you could also have a faulty remote
May 08, 2017 | Heating & Cooling
Remote with new batteries won't work
Even after replacing new battery cells only ON/OFF button responding and other buttons are not responding. Pl suggest how to solve it
Jul 15, 2012 | LG LSC121PMA Split System Air Conditioner
GE split air unit.remote is intermittent.I have 2 remotes same problem. Should I replace the display board or the pc board it plugs into?Which one controls the signal?
Replace new batteries and check. Switch off ac,remove any dc wire from indoor unit and then re-fix it.Now try. If still problem, repair/replace PCB
Jun 01, 2011 | GE Quiet-Aire Ductless Mini Split System...
Nec split system air con will not respond to remote control.
Jan 27, 2011 | Heating & Cooling
Remote won't work
The remote stopped working. So I changed the batteries Then remote signal's are OK But Indor Unit is not controlled by remote.
Feb 01, 2009 | LG LSC121PMA Split System Air Conditioner
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
