Question about Refrigerators
The flaps no longer close fully when the unit is turned off. Why?
Fujitsu Inverter. It is about 8 years old. The unit does not fully close when turned off.
    Sergeant:
  • 197 Answers
Theres probably some dust built up on the control arm preventing full retraction of blades - Get it serviced perhaps... the age tells me that it may well need a filter clean as well - breeding ground for germs...
Posted on May 08, 2017
Air condition system is no longer working and the person who checked it out says it needs a new system installed
get a second opinion when this statement is made
ac units only need replacing if parts are no longer available for repairs or the quoted repairs make it uneconomical to repair when compared to new units
for example
if your units is 15 years old, parts will be scarce and if it needs a compressor the cost of the part and labor will be close to the price of a new unit
new units are inverter units and are less costly to run and the larger units have reverse heating capability which makes them a heater unit in winter
best advice -- get a second opinion and then quotes for new units and make a decision on that information
Jan 22, 2017 | Cars & Trucks
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Daikin Split AC :- Vertical airflow flap not closing properly
Something is broken at the joining of the door which is not allowing the door to close
Apr 24, 2014 | Heating & Cooling
Hood is not retracting fully into catches that hold it down,side flaps also stay up,will then not close electricaly from this position,only manualy
There is a micro switch in the latch that seems to fail too often. Does the over-head warning lamp continually flash ? If so, this is an electrical problem.
The side flaps should lower when the top is fully secured in either up or down positions.
The side flap motors seem to be about as durable as the rear side window lift assembly in this vehicle, which is not long. Side rear window lift assemblies are replaced a lot when the vehicle is around 5 to 6 years old..
Due to the complexity of the system and the need for a factory manual or experience to locate all the safety features and switches to this system, you need to consult your dealer.
Feb 19, 2011 | 2003 Volkswagen New Beetle Convertible
Hi I have a Fujitsu Siemens Scaleoview C19-6 monitor. Recently it started going black randomly while I am using the PC. The green light at the bottom is still on and to get the picture back I must switch...
christelledt, When black screen of death rears it's ugly face, the first thing to do is look at the "date of manufacture" on rear of the unit! If unit has lots of "ON" time (300 days/year x 8 hrs/day x years in service) it may need to be replaced or refurbished. 7 to 10 thousand hours is middle to old age in monitor life. If unit performs in same way when connected to different pc then you will trade-in for new or investigate a DIY refurbishment of the units internal ac to dc switch-mode-power-supply/CCFL inverter printed circuit board. unit may need $5 in capacitors replaced to fix it. Plenty of info and videos on that on the web and here at fixya. 12fixlouie
Aug 18, 2010 | Fujitsu Siemens Computers & Internet
Last couple of years if our thermostat is set below 74 the ac will freeze up. The last 2 years we had it checked out and were told that 1)coils might be going out and 2) needs more freon. Once freon was...
Hello
If your going to have all the freon taken out,this current tech needs to find the leak.
Clearly from what you have said the unit has a freon leak.Freon is put in by ounces or pounds depending on the size of the unit,then you need to get the correct operating pressures.Coils do not go bad they either get full of dirt or get a hole in them.
An 8 yr old unit is a tough call,surley a new one will probably save some electric and come with a warranty.I would get some quotes on a new one,then see how much i could spend.
May 20, 2010 | Fujitsu Heating & Cooling
Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
Jan 05, 2009 | Fujitsu 18C1 Air Conditioner
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
