Streaming movies i havent seen - Computers & Internet
    Scholar:
    New Friend:
  • 69 Answers
And the question?
Posted on May 08, 2017
I have a Roku 2, live in the country and am trying to play a movie. It keeps stopping a reloading. what is wrong or what can I do?
Roku is an excellent streaming media player, but is ultimately limited by the delivery rate of your ISP's (Internet Service Provider's) continuous download speeds, used for streaming over the internet. ( Check what kind of speeds you're getting...) Go to http://www.speedtest.net/ and click on "Begin Test" There are a number of websites you can use to check your connection speed to see if this is the source of the issue.
Most often, a slow connection, (under 300kbps) will cause the issues you've described. The slower the connection, the bigger the problem. This is most observable on Roku channels that don't detect, or compensate for slower connections, especially at high definition streaming rates.
( 720 High-Def streams work well above 1.5Mbps download rates, and 5Mbps is recommended as good rate for 1080 viewing)
At just under 3Mbps over DSL, we're able to watch two movies at the same time, in different rooms, on Netfix, at 720. I've heard that some people are experiencing issues watching just one movie delivered with a cable modem... Not sure what's going on there?
Some Roku Channels are better than others at delivering the best possible viewing experience. Some use poor compression technologies, or only deliver a 1080 Definition image. Using the best compression technology, detecting best streaming rate, etc... are where the most successful Roku channels come in.
Netflix for instance attempts to detect the optimum streaming rates for slower speed connections, and automatically compensates by reducing image definition when needed.
You might try selecting a lower definition for your display from the settings menu on your Roku device... I've seen some improvement with loading issues, by choosing a lower definition display for your television, even though you might be using a high-def television.
Jan 01, 2015 | Roku Televison & Video
1. My 2008 MacBook Pro rejects most cd's and dvd's, has a Intel 2.5 GHz Intel core 2 processor. 2. When I downloading or streaming movies they keep re-buffering
Solving Problems with Streaming Services
If the Server Does Not Start Up or Quits Unexpectedly:
  • Check the error log.
  • Make sure the QuickTimeStreamingServer file is in the /usr/sbin/ folder.
    You must be logged in to the server computer as Administrator (root) to see the QuickTimeStreamingServer file in the Workspace Manager.
  • Use the Mac OS X Server Setup Assistant to reconfigure the Ethernet ports.
If Media Files Do Not Stream Properly:
  • Make sure the movie file is supported by the QuickTime Streaming Server. Check the list of compatible file formats.
  • Try streaming a sample movie to see if the server can stream it. You can download a sample prehinted movie from the Apple Software Updates Web site: http://www.apple.com/swupdates
    If the server streams the sample movie, the problem you're having may be with the way your movie file is prepared. Recreate the movie.
    If the sample movie doesn't stream, the problem you're having may be with the server computer or the network.
  • Try hinting the movie again with the Optimize Hints For Server option selected.
  • Check streaming server activity and if necessary, reduce the number of connections or throughput.
  • If the problem occurs on a Mac OS client computer, open the TCP/IP control panel on the client computer and make sure MacIP is not selected.
  • If the problem occurs on a client computer, make sure the user has the appropriate settings in the Streaming Proxy and Streaming Transport panels of the QuickTime Settings control panel. The administrator for the client computer's network should be able to provide the correct settings.
  • If the problem occurs for media streamed using PlaylistBroadcaster, try hinting the movies again with the RTP Payload Encoding set to QuickTime and Smooth Data Rate enabled.
  • If you are reflecting more than one live stream, make sure each stream uses a separate UDP port. Otherwise client computers will show a message with error 500. You set up ports in the relay configuration file.
If Streaming Service is Slow:
  • If you are streaming QuickTime movies, make the movies self-contained using your authoring application, and make sure hinting is optimized for streaming services.
  • Reduce the maximum number of connections or the throughput.
  • Turn off other services.
  • Place media files on other hard disks to improve server performance.
    Because QuickTime Streaming Server can use only one media folder, you need to create links from the folder you have selected in QuickTime Streaming Admin to the media files on other hard disks. To do so:
    In the Workspace Manager, press the Control key and drag the folders that contain the media from the other disks to the folder you have selected as the media folder.
Aug 04, 2011 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
