Question about Kenmore Washing Machines
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
When the washer was set on rinse and spin 20 Minutes , the drum would not spin fast, it would spin slow and sometimes speed up a little and it would take about 2 1/2 to 3 hours for the timer to count down from 20 minutes down to 1 minute and never finish the cycle when the GREEN light was on spin. Everything worked normally, had a code but went away after washer reset.
  • Gene May 08, 2017
    """""UPDATE""""" """""""UNPLUG THE WASHER FROM THE AC OUTLET""""""" ALWAYS USE CAUTION AND COMMON SENSE WHEN WORKING AROUND ELECTRIC AND WATER. This should work for several Kenmore front loader washers and models.... The problem is the wire harness that goes to the washer drum motor. There are two connectors, one BLUE and one WHITE, the BLUE connector is for the motor and the WHITE connector is for the stator. These connectors are located on the back of the washer to the left after removing the back panel. These connectors have a plastic bag over them to keep them dry. ( FOR ME, MY PROBLEM WAS THE WHITE WIRE ON THE WHITE CONNECTOR, THE WIRE HAD BROKEN BECAUSE IN THE FACTORY WHEN THEY WERE MAKING THE WIRE HARNESS THEY MADE PERFECT CIRCLE CUTS AROUND THE WIRES "SO CALLED STRESS CUTS" TO PREVENT WIRE BREAKAGE, BUT ALL IT DID WAS MAKE THE WIRE BREAK EASIER), the break was where the harness came down to the bottom of the washer, it rests on a plastic clip with a wire tie holding it to the plastic clip. "THIS IS WHERE MY HARNESS HAD THE BROKEN WHITE WIRE", it broke because they did not leave enough room for the harness to flex when the drum was spinning. Remove the damper/rotor its ONE CENTER BOLT,( was easier for me to get the connector off ) be careful when removing the connectors from the motor and stator. Disconnect the harness from both the blue and white connectors, from the motor side, and the zip tie holding the harness to the plastic clip on the bottom of the washer. There are also 3 plastic clips holding the wires stationary with 3 short Philips screws. Use an ohms meter to check for wire breakage, FLEX THE WIRES WHEN CHECKING THEM TO MAKE SURE THERE IS NO BREAKAGE, remove the white tape, easier to cut it "( CAREFULLY )", and visually inspect the wires. """""MY WIRE REPAIR""""" I cut the wire back and soldered in a short wire extension, ( Same gauge or bigger not never smaller ), and used heat shrink tubing to protect and seal the wire from moisture and shorting out. Use a good 3M electrical tape to re-wrap the two harnesses back together and don't forget to put the connectors back in the plastic bag!!!!! If no problem is found check the rest of the harness going to the power control board. This fix should get your washer up and running again. """"""""""""ALWAYS USE CAUTION WHEN WORKING AROUND ELECTRIC AND WATER, BE SMART""""""
    Sergeant:
  • 239 Answers
Sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
Posted on May 08, 2017
Testimonial: "Thank you for your input, but unfortunately this is not my issue."
Kenmore front load washer: 4172952990. Does not spin. Clicks... at the beginning of a cycle it will spin for a few slow spins, then nothing. Had the Sears technician in. Said that it was the Speed...
Our kenmmore front loader is having a problem with the pump. When it empties there is dirt with the water. Is there any way I can get at the pump and clean it? It is working 70% and as long as I have the drain hose on the ground the water will drain. When I shake the hose dirt comes out and sometimes it says F21. Can anyone help.
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
77 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
