Question about Cell Phones
How do I enter my code? - Cell Phones
2k 13 cheat codes on xbox 360
    +3 Ball Handling Enter "spriteeffect" as a code to get +3 Ball Handling for your player in MyCAREER mode. 2013 All-Star uniforms Enter "mwpzoslqov" as a code to unlock the 2013 All-Star uniforms. Christmas uniforms Enter "mnspxuwmdy" as a code to unlock the Christmas uniforms. Heat White Hot uniform Enter "kqpxmzodqb" as a code to unlock the Heat White Hot uniform. Secondary road uniforms Enter "ypzbnwolaw" as a code to unlock the secondary road uniforms. Under Armour Tourch shoe Enter "underarmour" as a code to unlock the Under Armour Tourch shoe. ABA ball Enter "payrespect" as a code to unlock the ABA ball.
    At the main menu, select the "Features" option, choose the "Codes" selection, then enter one of the following codes
Sep 04, 2014 | Video Game Consoles & Games
Can you give me the cheat codes for nba 2k13 for ps3
  • Enter "spriteeffect" as a code to get +3 Ball Handling for your player in MyCAREER mode.
  • Enter "mwpzoslqov" as a code to unlock the 2013 All-Star uniforms.
  • Enter "mnspxuwmdy" as a code to unlock the Christmas uniforms.
  • Enter "kqpxmzodqb" as a code to unlock the Heat White Hot uniform.
  • Enter "ypzbnwolaw" as a code to unlock the secondary road uniforms.
  • Enter "underarmour" as a code to unlock the Under Armour Tourch shoe.
  • Enter "payrespect" as a code to unlock the ABA ball.
Cheers,
Tom
Aug 27, 2014 | Sony Playstation 3 (PS3) Console
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
RESETING INTRY DOOR CODES FOR A USED 2010 MECURY GRAND MARQUIS
You have to have the factory code to progam a new code in one code is perminantly programed the sedond code can be entered after the original code is put in. by following these steps
1. Enter the factory set code. Note: The keypad and the interior lamps
will illuminate when pressed.
2. Within five seconds press 1 • 2 on the keypad to enter the
programming mode.
3. Enter your personal 5-digit code. Each number must be entered
within five seconds of each other.
4. Press 1 • 2 to store the first personal code.
5. The doors will lock then unlock to confirm programming of the new
code.
To store a second personal code:
programming mode.
3. Enter a second personal 5-digit code. Each number must be entered
If you dont have the original code you will have to find a factory scanner to retrieve the code some places will do this for free others charge. The code cn usually be found in the owners manual on a card.... if not to the dealership is where you will have to go
Jun 03, 2011 | Mercury Grand Marquis Cars & Trucks
How chanche code for unlock doors
2. Within 5 seconds press the 1-2 key
3. Enter your personal 5-digit code. Each number mus be entered within 5 seconds of each other.
4. Doors will lock and then unlock to confirm that your new code has been entered and accepted.
NOTES:
1. The factory code will still work even after you have entered your new personal code.
2. Entering a new personal code will erase the previous personal code.
Jan 11, 2010 | 1996 Ford Explorer
Can't find roku.com/link to enter code
where do I enter my code I reset my roku to factory reset?
Dec 19, 2009 | Computers & Internet
Garage door keypad
It doesn't work "enter..code..enter." It works "code..enter."
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I enter the radio code for 1993 volvo 850
To enter the codeAfter installation or when the set has been disconnected from power, the set displays "codE" when it is switched on.
Enter the 4-digit code using the preset buttons. If the correct code is entered, "on" is displayed and the
set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
After two hours have elapsed, re-enter the correct code.
NOTE: During the two hours waiting period, the set must be connected and turned on.
May 11, 2009 | 1996 Volvo 850
Forgot my security code please help for razr v3 motorola
If you want to unlock your Motorola phone to use it on another network, consider unlocking by entering a code. Code unlocking is the easiest way to remove the SIM lock of your handset. Just enter the code with the instructions below and it's unlocked. If you don't have a code yet, you can get one in my eBay store here:
How to Enter Unlock Codes on Motorola phones:
  1. Switch ON your phone with a not allowed SIM Card,
  2. Phone should show "Enter Special or Subsidy Code",
  3. Enter unlock code.
  4. Your phone is now unlocked.
WARNING: if any of these messages appear :
- "Contact Service Provider"
- or "Tamper Alter"
- or "Wait Before Enter Special Code"
- or "Contact Service'
It's because you or somebody else has already entered too many wrong codes. You just have to leave the phone ON on the error message and after 1hr - 8hrs the message "Enter Special Code" will appear again!
Note: If your phone is on a 3G network enter **057*, then another window will appear to enter the unlock code.
How to Enter Unlock Codes on all Motorola L6i & L7i:( not L6 and L7 without i )
  1. Press and hold "*" key by dialing code 787090
  2. The mobile displays: "Menu. Network"
  3. Choose 'yes' and then press OK
  4. The mobile ask you for code
  5. Enter the code for unlocking.
How to Enter Unlock Codes on all Motorola A1000 and other A models:
  1. Click on the icon Phone
  2. Enter the following keys: **057*
  3. Mobile displays "locking enter personalization"
  5. Click Ok
Feb 15, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
