Question about Orbit Garden
I can't adjust the rotation on a orbit 3 sprinkler. It is gear driven.
    Master:
  • 534 Answers
Https://www.youtube.com/watch?v=vT6bopOZK3A
Posted on May 08, 2017
Where do I get a new gear box for traveling sprinkler Orbit
Once again a couple simple GOOGLE searches...
Here is the item on the ORBIT website.
Orbit Irrigation Traveling Sprinkler Motor Assembly
I've never bought anything from these companies so I don't know how legitimate they are. Use at your own risk!
Orbit Traveling Sprinkler Motor Assembly
Aug 02, 2016 | Orbit Garden
Orbit traveling sprinkler won't move wheels turn when in neutral but not on high or low setting worked fine last night now nothing!!
I have a brand new orbit traveling sprinkler and the wheels won't move - they're frozen. The directions say to "Pull out the stopper underneath the sprinkler between the back wheels ..." and there is a white knob attached to a spring. When I try adjusting that, the wheels stay locked, frozen, won't move. What am I doing wrong?
Aug 11, 2014 | Garden
Orbit sprinkler manuals
Check for obstructions in the mechanism. Follow the instructions on the adjustments.
Aug 09, 2014 | Orbit Irrigation 58308 Tripod with Brass...
Is there a manual for the orbit h2o-6 gear drive sprinkler on tripod?
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 24, 2014 | Orbit 58565N H2O-6 Gear Drive Sprinkler
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Impulse sprinklers stick after cloclwise rotation; no return
i wouldbet it is a pressure related problem , can you isolate them so you are only running 1 at atime? at least reduce the number of sprinklers running at the same time just to test them, drop the number by1or2 and i`m sure your problem will be fixed youdoit
Jul 22, 2009 | Orbit Sprinkler System Power Source...
Garden Logo
85 people viewed this question
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
