Question about Pioneer Car Audio & Video
Pioneer 5500t car amp hooked to stero has blinking blue power light. replaced ground and rca and blue wires between amp and head unit. still blinking blue
james klgr
  • 362 Answers
SOURCE: Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Posted on Dec 12, 2007
SOURCE: Pioneer DEH 3700 ground problems/system noise
Very common with pioneers. their is a ground loop fuse-located inside the head unit, that has to be repaired at the factory. Or, the best way-just like you said, is to ground the rca's, solder a thin wire to each rca, easiest and cheapest way. I had it happen to me with a 4800.
Posted on Mar 26, 2008
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
  • 132 Answers
SOURCE: what is the light blue wire exiting cdx-l550x car stereo
THE BLUE WIRE IS USUALLY POWER ON SIGNAL TO AMP FROM DECK HOPE THIS IS HELPFUL GLENN
Posted on Nov 15, 2008
SOURCE: amplifier does not turn on when head unit is turned on
Wow guess you dont need help sound like you need a new amp! ohhhhhh wait I changed my name and NOW DO YOU SEE HOW HARD IT IS TO GET A NEW NAME YOU HALF WITT WANNA BE ******???????/ ENJOY AND GOOD LUCK BECAUSE I TALK TO OTHER PEOPLE WITH THIS NEW NAME TO.......HOW MANY NAMES DO YOU WANT ME TO COME UP WITH. i CAN COME UP WITH ONE EVERY THIRTY MINUTES.........HOW MANY TIME YOU GONNA POST A NEW QUESTION............. OHHHHH AND DONT FORGET THE ABUSE BUTTON ON THIS ONT TOOOOO BECAUSE MY NAME ISNT ON THIS ACCOUNT EITHER JUST ANOTHER FREEEEEEE E-MAIL ACCOUNT SOOOOOOOOOOO HAVE FUN AND CRY YA HEART OUT........UNLESS IT IS THE FBI YOU CANT TOUCH THIS AS OLD SCHOOL MC HAMMER SAID.
Posted on Jan 07, 2009
How do I hook up a jbl 12 inch subwoffer to a car head unit
The head unit should have a RCA Sub Out. The RCA wire goes to the Sub Amplifier, along with power, ground, and a blue remote wire from the Head Unit. Next, the Sub Amp is wired to the Subwoofer with speaker wire. Without an amplifier your sub won't make any noticeable sound.
Oct 09, 2011 | 1998 Ford Taurus
My Pioneer GMX552 Seems to have been hooked up properly, with power and the speakers have power to them. The RCA pin are connected, however I am not receiving any sound. Can I get a list of...
i doubt its the rca cable. check the connections from the back of the head unit, also check that you didnt blow any fuses either from the wire from the battery or on the amp also check the remote wire (little blue wire) and make sure its grounded really well
Mar 26, 2011 | Pioneer GM-X522 Car Audio Amplifier
PIONEER DEH-P86DHR NO SOUND!!
With these units, the internal amplifier is an IC that fails sometimes. It can leave the rest of the unit working ok, bit will have no audio. There may be audio from the line level RCA's but not from the speaker outs. Smell the back of the unit to see if it smells burnt. Most of the time it will, but not always. The IC is usually something like a PAL007a or similar. If you are good at soldering, you can order the part, and change it yourself. If not, you will need to seek a technician to replace the part. You may also try an external amplifier and RCA's instead of fixing the IC.
Jun 15, 2009 | Pioneer DEH-P86DHR
Have power good ground and remote wire has juice, no sound
no you can buy a 5 dollar volt meter at walmart or autozone to test to see if your rca wires are outputing any signal/ (volts) that will tell you if its the rca wires or head unit!
thanks
erik
Feb 26, 2009 | Pioneer GM-7100M Car Audio Amplifier
No power with amp
make sure the remote wire has juice when the head unit is on then check ground
Nov 25, 2008 | Pioneer GM-7100M Car Audio Amplifier
Soundstream300 amp how do I hook it up to my pioneer head unit
That depends on which wires you are referring to. High level inputs or low level (RCA) outputs? If you are thinking about trying to wire the amp up to your Pioneer direct, ie; running the power and ground off of the factory harness, think again, you'll fry your electrical system. You need to run a seperate power kit (8 gauge minimum; 4 gauge pref), then run RCA's from the line level outputs on the Pioneer. If you are planning to run a sub with the Soundstream then run your RCA's from the Pioneer's sub output. Let me know if I can help you any further.
Aug 17, 2008 | Soundstream EGA900D Car Audio Amplifier
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
Aug 04, 2008 | Pioneer 50W x 4 MOSFET Apple iPod...
Mar 23, 2008 | Pioneer DEH-3700MP CD Player
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
you'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Mar 13, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-P2600
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
