Question about Garden
My mower went limp wont accept fuel, ive checked everything.?
Ive a Falcon Fairmont Ghia 04 after driving through a big puddle today the car stalled &went into limp mode something has got really wet can you help me please
All the electrical plugs should be weather pack plugs. this type of water and the low pressure of it, shouldn't get into them. If it was a lot of water, check the air filter. If it is misfiring, check spark plugs wires and or coil boots. which ever you have.
Jun 04, 2016 | Cars & Trucks
It will not go pass 30
check the fuel filter, if it plugs up this can cause no fuel flow to engine. Also check the air filter and the plugs, and wires, if not the filter. It can be most anything but hope this helps. or it may of went into limp mode, if so call or take it to a garage.
May 06, 2016 | Cars & Trucks
Hi! i have a 2003 2.0L jetta. i was driving it everything was fine, i stopped the engine went for groceries when i wanted to start it the epc light when on and the car didnt start. we push it to start it...
I takes it your car is a manual shift and if so then you need to
Replace the starter switch that is on the clutch the winds the signal to the computer to start engine.
Oct 19, 2013 | Bosch 2003 Volkswagen Jetta GL 2.0L...
I have a cub cadet lawn mower 1550 it wont start i change the solinoid and checked everything i can think of keyswitch safety switch on clutch oil pressure sending unit it dont seem to be letting any
If it is cranking and not starting, check the switch on the bottom of the bowl. Those go bad I just recently changed one. If that is not it than please explain a little more. your paragraph ended abruptly.
Oct 18, 2012 | Garden
1 month ago my x type went into limp mode. Mechanic had it for three days and could find nothing wrong. Then today it went into limp mode four times. No warning lights on dash
The only time a vehicle goes into limp mode is when there is ****** problems, so I would take it to the ****** shop for code retrivel and if I am not wrong there might be problem with the Input/Output speed sensors BUT do have it checked first.
Sep 16, 2011 | Jaguar X-Type Cars & Trucks
I have a 2004 grand prix 3800 engine non turbo. Engine was eratic at cruise with rpms at 1200-2000. rpms would lope 2-300 rpms. I Changed air and fuel filter, and cleaned the throttle body. also checked...
i had a problem with all my lights coming on in my 2006 explore took it to dealer to find out that the battery was dying replaced it and they went away
Mar 26, 2011 | 2005 Pontiac Grand Prix
My 99 impreza turbo wont start.
FUEL PUMP MIGHT STILL WORK,BUT IT MIGHT NOT BUILD UP ENOUGH FUEL PRESSURE.ALSO COULD BE M A S,,,MASS AIR FLOW SENSOR,CHECK IT CLEAN IT,OR REPLACE IT..YOUR THROTTLE POSISTIONING SENSOR ALSO.IF IT MOVED OR FAULTY CAR NO GO.I HAD IT,REPLACED AWAY I WENT...OTHER SIMPLE IS FUEL FILTER
Dec 08, 2009 | 1999 Subaru Impreza
What else to check?
Check your fuse for the transmission if it is an automatic. It may have went into a limp mode without power to the soleniods as such all you will have is 2nd gear and reverse. Also the PRNDL switch may not be getting power too, so it would give you trouble starting.
Jul 13, 2009 | 1998 Chevrolet C1500
Merc 190e
Ok there is a number of things that will stop it from revving past 3k from your description I would check the ignition timing for advance mechanical and vacuum .I don't know when you experience the fault or eg while driving or just free reviving in Neutral .
BTW 190e does not have limp home mode so there is a real problem. Hope this helps
Dec 05, 2008 | 1990 Mercedes-Benz 190
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
