Question about Garden
Poulon lawn tractor model stx175g42 stalls; fuel starvation?
4x4papa
  • 14 Answers
SOURCE: Engine starts, but stalls when clutch is released.
The is a safety switch located underneath the mower, in the dashboard area. This switch will not pass voltage to the ignition system unless the pedal is depressed, or the deck is not all the way up. However, your culprit is most likely the pto (power take off) switch on the dash that engages the blades. It will not allow the mower to start, if pulled, and if faulty will shut off ignition power when you release the pedal. First. You'll need a volunteer to sit on the mower and operate the controls.  Now put the deck down and with the pedal depressed start the engine. Nothing should happen, if it does replace the deck switch Sears part number #176138 mentioned above. Now raise the deck and release the pedal. Again, nothing should happen. Same solution if it does. If nothing happens on both tests the switch is ok. NOW. Behind the dash, find the pto switch, and squeeze the sides, depressing two clips that hold it in the dash. You should now be able to slide it though the dash, wiring attached. Unplug the switch. With pedal depressed, deck up, someone sitting on the seat, start the mower. Now release the pedal (making sure to block the wheels and have the transmission handle is in the neutral position. If the engine continues to run, you found the problem. Replace the PTO switch. Sears part number # 174651. Also, check the plug to the pto, ignition and deck switches for corrosion as this is a common problem, though not likely to cause yours, it could. Good luck, and please let us know the outcome, good or bad. Thanks so much.
Posted on Nov 16, 2008
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
canbruce75
  • 1776 Answers
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Posted on Aug 31, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
How do i fix a lawn mower that start then after 2 or 3 min it will stall.
remove and clean carb , change fuel filter , check fuel tank for obstructions ,is there a problem with choke
Jul 30, 2015 | Garden
What causes a Poulon Pro riding mower with a 19.5 HP Briggs to shut down after only running for about 15 minutes?
Will it start rite back up?
Check to see if you have a low oil sensor,
Sometimes the oil sensor wills me it shut off when it's a little low on oil.
May 17, 2015 | Poulan Pro 19.5HP Lawn Tractor 960420123
It runs for 10 seconds then stops
Sounds like fuel starvation try each of the following, test to see if it runs after each.
1. Check you have fuel.
2. Check/replace the fuel filter.
3. Check the fuel lines.
4 Clean the carburettor
Aug 04, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sears lawn tractor
Check fuel tank or cap vent to be sure it is not plugged.
May 03, 2013 | Garden
Cub cadet RZT 22 starts but dies after a few seconds
Sounds like a fuel starvation problem to me the carbitrator need cleaning and inspecting for a blocked jet if there's is a jet blocked the an ultra sonic carberetor clean and service is required
Apr 20, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Poulon 96012002000
it is normal for the wheel with the least resistance to spin riding lawn mowers are not driven by both wheels you would tear up the lawn on turns
Jun 09, 2012 | Garden
Spark plug part number for poulon 17.5 hp lawn tractor
RC12YC isthe plug and gap it .030"
May 24, 2012 | Garden
John lawn 345 lawn tractor runs for about 30 minutes and then dies.
something is either heating or plugging up and causing fuel starvation.
Apr 04, 2011 | John Deere Garden
17 hp b/s will only run with choke on
your Mixture is too lean. or you have Fuel starvation. Check you carburettors needle valve, float bowl, and Mixture control.
Apr 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
