Question about Samsung Refrigerators
Needto connect water pipe to mains model number
Needto connect water pipe to mains model number rs21dcns
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Run 1/4" water line from source and connect to water inlet valve on ref. with 1/4" compression fitting with 1/4" sleeve.
Posted on Jul 26, 2009
Samsung rs21dcns
Did you thaw out the water tank and reinstall your filter
Jul 25, 2013 | Refrigerators
There's only one pipe for water is it a cold water dishwasher or hot model number adp755
If there is only a single water inlet then it has to be connected to the cold water connection. Generally dishwashers use internal heater elements to heat the water during relevant wash and rinse cycles.
Hope this helps.
Jan 02, 2013 | Whirlpool Dishwashers
Small header tank feeding dishwasher becoming contaminated,could this tank be piped out and connected to mains supply serial number of unit is 64318257. have approx 6 bar water pressure around site
Your dishwasher should not be fed from the header tank, it should be connected to the mains supply unless there is some sort of problem with your supply. I hope your drinking water is not connected to the header tank also!
Jan 11, 2011 | Washing Machines
Where is the main overflow pipe on my goodman furnace ac model number A24/10
follow the white pvc drain pipe to it .the over flow is next to the drain pipe.. this should have a cap over it .if your furnance is leaking water the drain is clogg.. use a shop vac to unclogg the drain pipe where it drains at the floor drain
Aug 22, 2010 | Heating & Cooling
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
Samsung RS21DCNS Water dispenser freezing up
Sounds like you have the freezer temperature set too low.
Oct 09, 2009 | Refrigerators
Connection of the water system to main pipe line rain soft
You have to have the city come in and set a meter before you can tap into the main line. After that you can run your piping to the house using 3/4" line.
Mar 18, 2009 | Plumbing
Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Oct 04, 2008 | Refrigerators
Samsung RS21DCNS
Dear friend,
ngfam at you service! happy to assist!
You can download the user manual at lg online and or order one there! It gives you specific instructions and diagrams how to install the water line!
HERE IS THE SITE TO GET THE MANUAL FOR LG
http://www.samsung.com/us/consumer/type/type.do?group=homeappliances&type=refrigerators
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
137 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
