Question about The Computers & Internet
The lower keyboard does not play. The upper works fine. Is there a fuse that I need to check? Where would it be?
  • 412 Answers
Highly unlikely that problem is caused by a blown fuse.
Posted on May 08, 2017
2004 Trailblazer lower taillights not working upper work fine.
With the condition of the screws you should check to make sure there is a good connection to the lower bulbs for both power and ground.
Dec 02, 2016 | 2004 Chevrolet TrailBlazer
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Convection upper oven not heating. lower oven working fine. blower on upper oven working fine and pre heat shows when oven us turned on but upper oven does not heat.
I Have worked on quite a few of these in the last few weeks, i have found that about 50% of these problems are caused by the control board and the other 50% caused by the thermal fuse, you can check the fuse by removing the unit from the wall and checking for continuity at the thermal fuse. If the fuse is in fact ok then it is the board that is not sending the correct amount of power to the elements. So the Power Control Board is what will need to be replaced, you can purchase both of these parts at, by using your model number.
Please rate my solution if it was helpful to you.
If you need more in depth information or pictures on how to remove and take this machine apart, feel free to ask.
Thanks, Repairman45
Dec 15, 2010 | Whirlpool GBD307PRS Stainless Steel...
The upper rear fan does not work. The lower is
it could be a fuse or the blower itself if the fuse is blown maybe the motor is bad, but yes fuse should be inside driver kick panel.
Jan 27, 2010 | 1999 Dodge Caravan
Key not working on Ispiron 1525
use your upper case i for lower case, and a upper case i and an underscore for the upper case I_etter.
Jun 14, 2009 | Dell 0Y3740 Keyboard
Upper screen on my NDS lite is not working.
if u think its the touch screen its not its just to see
Jan 18, 2009 | Nintendo DS Lite Console
Top Rear brake light works, lower two brake lights don't
This is known problem, and it is the turn signal switch.
Sep 09, 2008 | 2004 Chevrolet TrailBlazer
Keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
