Question about Electrical Supplies
How to reset a breaker on 6000 dg generator - Electrical Supplies
    Master:
  • 534 Answers
Explained here:
https://servicenet.dewalt.com/documents/English/Instruction%20Manual/0068660,DXGN.pdf#_ga=2.65557742.1315046841.1494211882-1118003391.1494211866
Posted on May 08, 2017
Tip
Generator runs great but produces no power
On Thursday last week I had 220 amp outlet being used and a 110 amp outlet being and overloaded the generator. It turned out to be the reset breakers failed to trip and blew the capacitor. The reset breakers I would suggest replacement after 7 years very easy to do on a 5500 Valsi generator 2010 model still running and now producing electric. And of course use only regular gas non Ethanol.
on Aug 19, 2015 | Electrical Supplies
Manual for DG 6000 GENERATOR
Make sure the main breaker on the top right is turned on then make sure the breaker for the outlet you were using on the generator is turned on. Also make sure you're not using it for something that draws more power than the generator can handle because the breaker will trip every time. If that doesn't do it And you're not familiar on how to test the actual generator with a voltmeter then you'll have to bring it in to be fixed. Also if I recall there is a switch that controls the voltage make sure the switch is in the correct voltage position according to what you're using it for
May 06, 2017 | Electrical Supplies
My Multiquip GA6HA generator only puts out 1 volt any ideas for troubleshooting?
Sounds like the alternator has failed, possibly a short or open in the windings. Similar to problem I had with my 10 KW unit. I replaced the alternator.
Jul 05, 2014 | Multiquip GA6HA Recoil Start 6000 Watt...
NO OUTLET POWER
There can be several causes for this symptom. Does the outlet have a breaker or "switch" that is tripped? If this is a GFI (ground fault circuit interrupter) outlet, first disconnect any cord or equipment plugged into the outlet, then press the "reset" button in the middle of the receptacle. The GFI's should not/will not reset with anything plugged in. (If they are working correctly.) More specific information needed if this does not take care of the problem. There are numerous other things which could be causing this problem, loose conections, bad generator, broken or damaged wires on the electrical system, inverter problems, etc. Refer to your owners manual if at all possible, take a look here at this link if you don't have a copy.<<< http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DG6000&selectedType=6326# >>>>
Feb 22, 2012 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
DEWALT DG6300B NO POWER OUTPUT
Hello avid.....
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Nov 27, 2010 | Garden
High voltage
Great, JP. Could I ask you to please rate my assistance. Thanks very much!
Charlie
Aug 20, 2009 | Coleman Powermate Powermate 5000W...
Quit generating power
There should be a breaker reset button. It should be by the plugs on the generator.
What kind of generator is this?
Dec 25, 2008 | Electrical Supplies
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
