Question about Mackie Music
Mackie SR24.4 VLZ pro.. The light lamp stopped working, bought a new one, still doesn't work. WHY
    Top Expert:
  • Mackie Master
  • 3,130 Answers
It's probably not getting power to the lamp connector. Get a voltmeter and check it.
Posted on May 08, 2017
Mackie 402 turning itself off help please!
You should return it, that's what the warranty is for. Don't even think about trying to sort it yourself
Nov 25, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Do you sell or know how i can get a manual for a 1642 vlz just bought brand new. Cheers G
The manual can be downloaded from the link below.
Dan
Link: http://www.mackie.com/pdf/archive/cr1604_om.pdf
Jan 10, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hello. I'm missing the bottm plate of the mackie 1604 vlz pro. I bought it on ebay and the bottom plate that covers the internal parts did not come with it. Is there anything I can do about this? Do they...
Mackie does sell parts. If you cannot afford or get the part, procure some metal and make your own. Mackie is headquartered in Woodinville WA I believe.
(800) 898-3211 Monday-Friday, 8am-4pm Pacific Standard Time
Aug 06, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I need a part. a fader for a SR24?4?2 VLZ PRO.
Removing all the knobs from a section of the board where the bad fader is can be a hassle.and sometimes some of the nuts from jack or screws from some connectors.
You are probably better to order the part from Mackie to get the exact part. Most are made by ALPS and I get ones for some equipment from DigiKey.com or Mouser.com. However, it does take a bot o knowledge to get the correct part and sometimes requires cutting the shaft of one that is too long.
One MUST match the mounting holes, resistance value, length of throw AND the "taper". Yours will probably be a standard "Audio taper" for the main output.
May 04, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Looking for sliders for mackie 1402 vlz pro how much are they?
You can purchase the channel faders directly from Mackie Service Dept., you can replace them yourself if you're good at soldering - HOWEVER, be advised that disassembling the unit to get at the faders to replace them will require a lot of time and patience if you've never done it before. If the faders are not moving smoothly, it's possible that the wrong type of cleaning spray was used on them and there's a possibility that they could stop moving and controlling sound.
Jul 27, 2009 | Mackie Music
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
