Question about Mercury Boating
Mercury outboard 115 hp - tilt and trim not working, engine will not start. 2 new batteries, all other accessories working except the stereo.
    Visited the website for 10 consecutive days.
  • 83 Answers
Does the engine crank? Sounds like it is possibly a bad ground somewhere. I would also check the voltage to your batteries and see what they are reading. Just because they are new does not mean that something is not draining the battery.
Posted on May 08, 2017
Starts up, then why does it cut out when going to full throttle?
possibly overheating try running slower which creates less heat
Oct 25, 2015 | Yamaha Tilt Trim Motor, 115-225 HP...
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Suzuki4stroke 150 hp will not start, new battery gets juice just clicks
starter solinoide sounds like it failed if its clicking ! remove engine cover and as a friend cranks the key listen where the click is and it will have the +wire from battery and then a wire to starter , check connections are tight and if all ok then replace solinoide !
Sep 07, 2014 | Suzuki Tilt Trim Motor, DT 150-200...
Install tilt and trim 75hp mercury
pending on how old your engine is coz the price of the full system is lots and mite be more than what your engines worth so check on price of engine with it fitted !
May 09, 2014 | Mercury Mark 75 Outboard Boat Motor...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Evinrude 225hp will not power tilt batteries OK manual release will turn but still not able to tilt motor?
Check trim tilt switch (if that's ok ) Try the trim / tilt relay inside the engine cover.
Could also be limit switch above the trim motor up further under the motor.
My bet is switch or relay
Good luck
Aug 14, 2010 | Clymer EvinrudeJohnson Outboard Shop...
Boating Logo
48 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Joseph Hoffmann
Are you a Mercury Boating Expert? Answer questions, earn points and help others
