Features of tv keep showing on bottom of the screen and I can't get it off of the screen
Cannot get full screen picture
Full screen resolution depends on the source signal that you feed to your LCD TV. Most often, the signal come in 16:9 screen size, which sometimes show big black portion on both top and bottom of screen. To maximizes screen display, you can adjust the screen size of your LCD TV through remote control, this features are available in most LCD TV. you will have the option to choose Full Screen Mode, 16:9 screen resolution or many others to choose from (most case about 3 to 4 screen size.
Jul 03, 2011 | Dynex DX-L32-10A 32" LCD HDTV
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
My tv keeps popping up 4+ series and a bunch of other things at the bottom of the screen... how do I make it stop doing this?
check the menu there may be some sort of "demo" mode or "Store" mode that the tv is set to. there are some features that are for the stores to use when tvs are being displayed instore. check owners manual
Dec 23, 2010 | Samsung Televison & Video
How do i get the language back to english?
Press the Menu Button on the remote to show on-screen menu.
Press Cursor Up or Down button to scroll through the on screen menu until the word Install is hilighted.
Press Cursor Right button to display the Install menu features.
Press Cursor Up Or Down button to scroll the install features until the word Language is hilighted.
Press Cursor Right button repeteadely to select English or Spanish [Espanol]
When finished press the Status/Exit button to remove the menu from the TV screen.
[The language control only makes the TVs on-screen menu items appear in English or Spanish. It does not change the other on-screen text features such as Closed Caption [CC] TV shows.]
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
52" rear projection. I can not see the scroll feature at the bottom of the screen during football games o news casts. i hav tried the normal mode on he zoom feature but still not showing.
Check the "Aspect" setting on the TV, it's probably set to "Zoom" If that's ok, check the settings on your cable/dss/fios, etc receiver. If you still have an issue, post a comment and I will help some more.
Sep 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a black rectangle that is showing up in the middle of my tv screen? It just started and shows up for about 30 seconds and goes away again????what the heck?
you inadvertantly turned the cc feature in the tv set on. look for the cc key on your remote control, press it repeatedly, tv will go through cc1,cc2,txt1 and so on... keep pressing till you get to where it says off. this should do away with the block
Jan 09, 2010 | Televison & Video
A "Critique show" text message keeps popping up
This is definitely not a Sharp Aquos feature. Any show related functions come from Dish Network. It might be a channel specific function which the Dish Network support staff does not know how to deal with.
Jan 31, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Half screen showing
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Konka TV
if you have an owners manual there is a special feature menu yu can go to that will fix how your picture fits on the screen. my tv was doing the same thing except it was the top and bottom until i played around with the remote and stumbled across the menu.
Jan 02, 2008 | Konka K2001UM TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
