Question about Saws
Jason is cutting a roll of sausage into pieces that are 1/2 inch thick. If the roll is 6 inches long, how many pieces of sausage can he cut?
  • 17,155 Answers
12 since 2 time 1/2 is one and there are 6 inches
Posted on May 08, 2017
How many pieces 3.25 x 2.0 inches can be cut from a 8 1/2 x 11 inch sheet of Cardstock?
12. 3 across and 4 down with both the sheet and the labels in landscape rotation.
Oct 24, 2016 | Office Equipment & Supplies
Recipe for cinnamon buns in a Charlescraft bread maker
DIRECTIONS
  1. Put yeast in bread machine (I use the top rated one at: http://bestbreadmaker-review.com) first on bottom, then flour, sugar and salt.
  2. Then melt butter in microwave. Add beaten egg, milk and water.
  3. Pour onto dry ingredients in bread machine on the dough setting.
  4. When dough is done, put it onto a lightly floured surface.
  5. Knead in enough flour to make it easy to handle.
  6. If it is too elastic, cover and leave 10 minutes.
  7. Use floured rolling pin to roll out dough on floured surface.
  8. Roll out into rectangular shape to approx 1/4-inch thick.
  9. Use filling and spread over entire surface of dough with spoon.
  10. Roll up dough.
  11. Cut into circle with a sharp knife about 1-inch thick; place these in a greased 9x13-inch pan.
  12. Cover with a tea towel and leave in a warm place for approx 30 minutes, until double in size.
  13. Bake in a 350° oven for about 25 minutes, light brown on top.
  14. When done, make glaze and swirl over buns.
Oct 17, 2015 | Kitchen Appliances - Others
How do I replace the spring in the latch door on my rn175
There are several methods for installing this little spring. My simple method. You will need 30 mm x 3 mm roll pin and a small piece of nail about 1/2 inch in length. It is very difficult to install the small factory roll pin so I use a longer one then cut off the access with Dremel. Remove the 3mm roll pin and pull out the lever discarding the broken spring. Fit the new spring on the lever using the 1/2 inch piece of nail that can pass thru the 3mm hole of the lever. The piece of nail should not stick out either side so that you can slide in the lever with short pin holding the new spring in place. Now insert the lever in place on the door and hold in position (temp pin aligned with 3mm holes in door ), lightly hammer in the long 3mm roll pin. The long roll pin will push out the temporary piece of nail holding the spring in place. Once the long roll pin is in place, cut off the extra length. Good luck
Sep 11, 2013 | Porter Cable RN175 Roofing Coil Nailer
How long to cook chicken sausage on the George foreman
this depends on how thick the sausages are. For sausages that are about 1 - 1 1/2 inches thick it will take about 10-15 minutes. the best way to tell if a sausage is done (chicken or pork) is to insert a meat thermometer into the end of the sausage about 3 inches deep. When the meat is done it will read 160 deg F.
May 03, 2011 | Vacuums
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
I need a spacewarp 5000 english instruction manual
I think everything up to step 12 should be pretty self explanatory.
Steps 13 and up are below
13 - Initial ramp
Cut two pieces of wire into 150 cm (59 inches) lengths (may need to be trimmed down once put on track)
Connect one end of each piece to J-3 then thread through the following order
G-7, D-4, C-5, F-6, H-4, I-4
Connect to track separator piece (the piece with the flipper)
14 - Track A (Loop)
Cut two pieces of 270 cm (106 inches) lengths (again, may need to be trimmed down once put on track)
Connect one end to the side nearest G then thread through the following order
E-3, D-1, D-2, C-1, C-2, A-1, B-1, E-2, G-2, I-1, H-1, F-1, E-1, G-1, J-1
Nov 13, 2010 | Bandai Toys
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
My sirius car antenna cable got cut by the trunk closing on it. I tried connecting the two ends and the system can not get a signal. What can I do?
Small heat gun.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 07, 2009 | Sirius Satellite Radio Receiver
Split hull
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Jun 01, 2009 | Boating
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Saws Logo
47 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
