Question about The Audio Players & Recorders
I have a BassCube 851 has power but no audio I have touched the audio input cables with my fingers and no feedback noise. Any schematics on this amp? or repair tips?
  • 19 Answers
SOURCE: Input Echo - audio feedback loop
do you record from
a) mic
or
b) line input ?
if a)
turn off your speakers, and use headphones.
or at least turn down the volume, and change the mics position (as far away from speakers as possible)
if b)
dont route the allready recorded channels to your master while recording (-> or mute them)
Posted on Mar 31, 2008
  • 13433 Answers
SOURCE: audio feedback
put your mic on mute for playback. So the mic works but it doesnt play it from the speakers at the same time.
If you dont see microphone on the list click on
options then settings
put a X on the playback -> microphone.
close settings
its now shown in the panel, click on mute and it wont feedback the sounds to you anymore.
Posted on May 09, 2008
SOURCE: I have a m-audio buddy
It appears that the condenser microphones that are omni directional are too sensitive to process thru an amplifier. I used an mlx 991 directional condenser microphone and though still very sensitive, I was able to avoid the feedback. According to the company condenser microphones are used more for recording and not so much for live stage.
Posted on Jan 06, 2009
  • 1138 Answers
SOURCE: cable broke off in the input jack
I'm pretty sure t6hat the output jack is a sealed unit(contacts inside soldered to the surface of the circuit board. You may be able to grasp the center shaft of the plug with a thin jawed hemostat or really skinny long nosed pliers and pull it out that way. Make sure the amp is off and unplugged from the wall. If that doesn't work you will either have to get it removed at a shop or disassemble the amp to remove the circuit board and unsolder the jack and replace it or get the broken plug out of the jack once it is unsoldered. I've never had a Line6 apart yet but thats probably the type of jack they used. Thats because it has to be electronically isolated from the chassis. Hope this helps.
Posted on May 15, 2009
  • 6 Answers
SOURCE: feedback issues.
Did you run your power and remote wires the same route as your RCA cables? If you dont run the RCA cables on the opposite side of the power and remote you will get feedback through your speakers. I run my power on the side closest to the battery along with the remote ( passenger in my case) and the RCA cables should be on the opposite side( driver side). They say the power current will create a disturbance in the RCA cables that you would hear as feedback. Hopefully this will help you.
Posted on May 29, 2009
Fix subwoofer
Pop open the back side of the sub and see if the to connections are soldered firmly to the wires/drivers themselves & make sure your system is grounded meaning the 3 pronged plug has to have the 3 post still connected to the power cord. If its broken off as most people do it'll cause that feedback or dull hummmmm noise.
Oct 15, 2013 | Altec Lansing VS4121 Speaker
MUFFLED SOUND, STATIC FEEDBACK AT HIGH VOLUMES
Check the sound in the headphones... It may be your power amps are giving out. MAKE SURE the interconnect cables are either XLR or TRS cables (balanced line). Make sure your power amps and the mixer are ALL powered from the same receptacle OR power conditioner module. You cannot power the amps from one end of a building room and the mixer frrom a wall receptacle at the other end. The building ground bounce can not only cause noise, but can destroy sensitive input circuits of the equipment.
Jul 09, 2011 | Mackie 2404-VLZ3 Mixer
The audio input jack is loose i'm guessing, so when i plug in the wire i have to move it around to get the sound to come out. i'm tired of having to move the wire every time it plug it in, what can i do to...
hi,
first of all try to replace the audio cable. if it has break inside then the same problem can occur. replace the cable and check the same.
if then also the problem remains. i think you are connected the cable to the R mono input. remove it from R mono input and connect the same to the L input.
there is no difference between the R and L input. if you connect it any input you will get the same out put.
If then also the problem remains then you have to replace the RCA socket in side you sub woofer. It will be difficult for you to replace the same. any way make a try.
ok
Apr 09, 2011 | Cambridge Soundworks BassCube 15 Speaker
I have a yamaha yst sw320 subwoofer connected to a yamaha dsp-a595a amp. I recently disconnected my equipment and when i reconnected it im getting a feedback hum/noise through the sub. I've tried...
Subs don't go to a variety of connections on the amp. Let's stop guessing and stick with the prescribed one.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Yamaha-YST-SW320-Subwoofers-manual/id/320bh340/t/2/
See page E1 regarding placement and safety.
http://www.retrevo.com/support/Yamaha-DSP-A595-Amps-manual/id/319ag821/t/2/
Page 44 - read about "humming".
If you have hum on the sub, is it there with and/or without the input cable attached?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 02, 2011 | Yamaha YST-SW320 Subwoofer
When then amplified is turned on, it generates a humming static noise. it plays music, along with that humming noise. would it be possible for us to receive the schematics of this model at...
What amplifier is this? Humming noise is normally caused by video cables in audio ports, high voltage wires too close to audio wires, or ground loops.
Feb 25, 2011 | Audio Players & Recorders
I am attaching an external microphone and need to mute the internal mic. They both work and it echos. PLease help.
Adding a mike doesn't create echos/feedback. Windows? Version? Right click on speaker icon in lower right and go to recording device mixers, can mute and adjust level of sound sources, also microphone power and pre-amp. Telephones and other devices (laptops) with both input and output will feedback unless the input is "noise cancelling", so you will have to be much more careful with the placement of the external mike compared to using the built in mike.
Oct 14, 2009 | Computers & Internet
Amp wont turn on, but i hear a pop when turning off
first off nothing should pop when turned off next it could be a grounding problem external or internal or worse an audio output problem take a volt meeter and turn key to on check the ground and positive on the amp should read 12 to 14 volts do same with ground and remote wire if these both read correct remove the back set your meeter to the diode setting the audio outputs are usually the larger ones but sometimes not take your leads and touch out side legs then to the outside to center try each one every way you can switching leads if at any time the buzzer stays on or goes to flat 0 then that output is bad if all check good i would go through the car making better connections and cleaning up any wires that might seem to be faulty maybe even replace your RCA cables
im running 18 speakers and 8 amplifiers in my car and i have done this several times :( but i don't pop unless something is wrong hope this helps
Jul 24, 2009 | Line 6 Spider Iii 30
Feedback issues.
May 28, 2009 | MTX Thunder 8302 Car Audio Amplifier
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
24 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
metsamehike
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
