Question about GE Blenders
I need replacement parts for GE Single serve Blender Model NO 898695 a. flat blade for grinding and b. cross blade for mixing
3 Suggested Answers
SOURCE: the jar of the ge
Most likely the problem is caused because the base is not screwed all the way on to the jar. This could be from just not turning it on all the way or it could loosen while running. Make sure the base is tightly closed before putting is into the power unit. To remove it you can lubricate the tabs with some vegetable oil and then force it. GE service suggested that. I have heard of two people joining forces to get it off without apparently damaging it but no guaranty's. If you have the reciept it should have a two year warranty, at least mine does.
Posted on Dec 27, 2010
SOURCE: GE single serve blender 898679--need replacement
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Posted on Jan 28, 2012
I need cross blade and flat blade for my Nuwave twister blender model # 22091 is there anywhere I can buy these parts?
I could sell you my pieces for a few dollars plus shipping. It's been a while so not getting hopes up, but if you still have yours, will sell my blades and cups to you. Or if you have a good base I may buy that from you. Mine burned out blending smoothies.
Chasgiltner@Gmail.com
3213457242
Feb 16, 2015 | Nuwave Twister Blender
Tip
Failure of grinding, blending, or mixing kitchen appliances
Generally, a blade or grinding or blending/mixing part that is permanently attached to a metal shaft from the appliance motor is held on that shaft by a 'shear pin'. This pin breaks when something is put in the appliance that the grinder, mixer, blender can't gring, mix, or blend. This is to protect the motor from overload. Afterwards, The motor will continue to turn, but the blade or paddle, or whatever will not turn.
The shear pin needs to be replaced.
The shear pin passes through one side of the base of the bade/grinder/paddle assembly, through the motor shaft, and out the other side of the blade/grinder/paddle.
The piece of the pin must be removed from the shaft, and from the two sides of the blending/grinding part. This is generally a press-fit, and some effort may be required to accomplish this.
When the pieces have been removed, a common 'roll pin' of the appropriate diameter should be inserted to hol the turning part on the shaft. It must fit tightly, and some effort should be required to insert the new pin.
on Feb 07, 2010 | Blenders
Ninja proffessional bl660 blender single serve not working but regular blender is
That is not SUBTLE...!!!
Go with the REAL BLENDER... I've never heard so much
horrible complaints... even from RALPH NADER...
(In my very humble opinion)...
Where there's complaints (tons of them)..
There's trouble.
The whining about ninja's here is quite amazing!!
Jan 31, 2014 | NINJA Blender with Single Serve Accs BL660
I NEED A PITCHER FOR BLENDER MODEL KSB540WHO
The jar assembly for the KSB540 is part W10503762. this is for the 48oz jar assembly. Here is a link to the product KitchenAid Blender Jar Assembly for KSB465
You can also use the 56oz jar on your blender, which is part number W10555711, here is a link to that product as well: KitchenAid Blade Jar Assembly W10555711
Nov 26, 2013 | KitchenAid KSB5 Professional Stainless...
G E single serve blender 898695-- need replacement parts
sure, amazon is best place for searching parts... take a look Healthy Blend of Power Precision and Value. enjoy
Jan 19, 2013 | GE Blenders
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
Mar 15, 2011 | GE Blenders
Hand blender bottom shaft (blade attachment) leaks oily stuff
In the old days, there was a packing in certain places of certain applications.
Often it looked like a piece of string, usually a grayish color, as it often was impregnated with grease.
I would start with an automotive parts house, but it must be old and have old folks to help you, as young ones have no such experience.
You could also try a plumber, they used some packing string.
As a matter of fact, I have some in my plumbing repair parts, though I've no used it in 30 years.
You might have to use this each time you use the machine.
It should be not expensive.
God bless your efforts.
Mar 26, 2017 | Kenmore Blenders
The screw that holds the mixing blade in place sheared off. Is there a way to replace this screw?
Try bonding the sheared portions with Araldite. Once it is set try slowly to unscrew. OR if you can make a little nich in the embeded portion so that tip of screw driver can fix it. Then it should be easy to unscrew the sheared portion. Otherwise no other alternative but to replace the attachment.
Jan 23, 2010 | Kenmore Blender Single-Speed Blender
Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
Blenders Logo
137 people viewed this question
Top GE Blenders Experts
Pamela Leach
Pamela Leach
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GE Blender Expert? Answer questions, earn points and help others
