Question about Symbol Cell Phones
The power on symbol just continues to go around but does not come on. I pressed power up and down volume button at same time, now I get "downloading do not turn off target"
freetek
  • 5568 Answers
SOURCE: Yurning up volume
I'm going to make an assumption (assume=*** of u & me) that you are dealing with an Intel/Win machine.
If not, forget everything I wrote here.
It's helpful if you mention what your system and OS is.
You will need to click or double click on the speaker symbol on the task bar; if organized as common, it will be on the right.
On Win XP, a single click opens only the voulume control, double click gives you a detailed panel (different audio cards/chips look different since this is a software function) that allows you to control the level of different inputs or file types.
The presence of a speaker symbol on the escape button is kind of puzzling but may be a function of an extended keyboard that requires a manufacturer's device driver to be loaded when you boot.
That may not be loading.
(Some icons may require double clicks-)
If yes, then click on the Start menu, select Control Panel, then Sounds & Audio devices (or similar), this will show you if the sound is muted and let you select default volume level and tell you whose audio is installed.
If it looks OK, close the window and then click on the System icon, then Hardware, finally Device Manager.
Check the list for open folders that involve sound devices for any red 'X' on functions.
If you find one, then something hasn't been installed or turned on and since we don't know the exact system you have, it may require different methods of 'fixing' the problem and then you will need a friendly nerd nearby to help you.
Posted on May 27, 2008
SOURCE: When volume button is pressed it does not stop going up or down
You can also use the cancel button on the SC-BT100 remote to keep the sound volume from accellerating up or down if you don't want to take the time to unplug for the 5 minutes, if your watching something and don't want to miss it.
Posted on May 19, 2009
  • 197 Answers
SOURCE: Volume turns itself to maximum
soft waer call phillips
Posted on Jun 07, 2009
danthomasdou
SOURCE: Anyone know how to set clock on iCoustic A-101 iPod Dock/Clock Radio?
Ok I have this figured out, if it's the A-101a dock, with the power turned off, double click the MEM/SET button, that will get you there! Choose from format first (24/12 hour time) then click again for hours and minutes. Took me ages, just figured it out!
Posted on Aug 02, 2012
gopakumarg43
  • 74887 Answers
SOURCE: Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Posted on Dec 05, 2012
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
1. Ensure the device is powered off.
Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
2. Press and hold the Volume Up/Down buttons then press the Power button.
Note When presented with the Boot Mode Selection Menu, release all buttons.
3. Press the Volume Down button to tap Recovery then press the Volume Up button.
4. From the DROID triage screen:
a. Press and hold the Volume Down button.
b. Press and release the Volume Up button.
c. Release the Volume Down button.
5. Select wipe data or Factory Reset.
Note Utilize the volume keys to highlight and the Power button to select.
7. Select Yes -- delete all user data.
Note Data wipe may take several moments.
8. Select reboot system now.
Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Oct 30, 2017 | Verizon Cell Phones
How can i reset my symbol windows mobile mc7090
did you try this?
  1. Performing a factory reset using phone buttons
    1. Turn the power off.
    2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button. Release the VOLUME DOWN button when you see an icon on the screen.
    3. Then press the following hardware buttons in sequence: VOLUME UP > VOLUME DOWN > POWER > VOLUME DOWN.
Feb 12, 2015 | Symbol MC70 Handheld Mobile Computer (P/N...
Forgot password how can I rest my tablet
1) Power off your tablet.
2) Press and hold Volume Down and Power buttons.
3) When The Samsung Galaxy logo appears, let go of the Power button and continue holding Volume Down button. Two Android icons appear.
4) When the two Android icons appear release the Volume Down button, then press the Volume Down button to move the cursor to the left; and then press the Volume Up button to make your selection. The Android system recovery menu appears.
5) Press the Volume Up or Down button to select "wipe data/factory reset", and then press the Power button to make your selection.
6) Press the Volume Up or Down button to select "Yes - delete all user data", and then press the Power button to make your selection.
7) When the reset is complete, press the volume Up or Down button to select "reboot system now", and then press the Power button to make your selection.
Sep 27, 2014 | Samsung Galaxy Tab 101 Tablet...
Hi, I just purchased a new optimus phone from Metro pcs. I tried to enter my password for my wifi and must of got it wrong and now it won't let me try anymore
Instead of hitting connect hit the forget button. If that doesnt work then factory reset your device. Turn power off to the device then hold the power, home, and the volume up button at the same time after the first sign of it powering up release the power and home buttons while continuing to hold the.volume up until the android symbol appears and gives you the options to do a factor reset. Scroll down to the factory reset then hit the power button. Oh use the volume buttons to scroll up and down to get to it. Hope it helps..
Jun 05, 2014 | LG Optimus Black Smartphone
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
How to reboot cherry mobile spark tv?
Here`s how to hard reset you Spark Tv
1. Turn off the your Cherry mobile Spark
2. Press power button, Volume down and home button at the same time.
3, Wait for a Spark TV logo then release power buttons and continue holding Volume down and Home.
4. Scroll down and select wipe data then press home button
5. Select reboot and your phone will be unlock but all files in the internal storage will be deleted.
or try this
SPARK TV cherry mobile HARD RESET too many patterns attempt solution
POWER ON + VOLUME DOWN BUTTON press together in 20 seconds or until the Android system recovery <3e> appeared
Press volume down to wipe data/factory reset then press power on
Press volume down Yes -- delete all user data then press power on
Press power on to reboot system now
After reboot HARD RESET was done
May 20, 2014 | Nokia E Cell Phones
How to reset my phone
  1. Turn of your mobile phone and reinsert the battery.
  2. Continuously hold the Volume Down button.
  3. Press and release the power button.
  4. You would be presented with the options like Fastbook, Recovery, Simlock and clear storage and now release the Volume Down button.
  5. Select the Clear Storage by pressing download the Volume Down button.
  6. Press and release the power button.
  7. Now confirm your decision: Volume Up for Yes and Volume Down for No.
So select YES to delete all the data including the third party applications from your Samsung Galaxy S. It will automatically reboot when the process is successful.
Jan 31, 2012 | Samsung Galaxy S 4G Cell Phone
New hyundai i30 has clock set to wrong time. the manual gives instructions to re set the clock for a different radio/cd player model to the one i have. mine does not have a SET UP button. in its place it...
Press the radio on button and hold down.
A menu appears, displaying Adjust Initial Volume, release the power button.
Turn volume button to the right to display the Clock menu item.
Press the power button to select the Clock Menu item.
Rotate the volume button to adjust the hour.
Press the power button to move to minutes adjustment.
Rotate the volume button to adjust the minutes.
Mar 17, 2011 | Hyundai Accent Cars & Trucks
Forgot my password to my htc pure. Can not unlock to use my phone
In that case you can reset the phone but this will erase all contents, contacts, downloads and your information.
Follow these steps to reset the phone.
  1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
  2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen : This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
  3. Release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Mar 09, 2011 | HTC Cell Phones
My htc is frozen if i switch it on it get freez displaying smart mobility no button works even switching it off pls help
You need to hard rest your phone... follow the steps
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
3. Release the VOLUME UP and VOLUME DOWN buttons, press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 03, 2010 | HTC Touch HD Smartphone
Cell Phones Logo
22 people viewed this question
Top Symbol Cell Phones Experts
castletech
castletech
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
Are you a Symbol Cell Phone Expert? Answer questions, earn points and help others
