Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Heater Problem Paloma gaz waterheater for a caravan, 15 years old approx. after its been stood for a week or more it takes a long time to light the pilot light, have to hold a lighter in hte pilot light area for a long time before it ignites the pilot light, once it is light it works perfect.
  • 54 Answers
It is normal problem because u r heater is so old
out of company warranty so open it and clean it
NOTE
dont touch it after use means open it before use
means when it is not use in 1 hours because heater contain power in one hour after use
Posted on Jul 25, 2009
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 07, 2013 | Water Heaters
Atwood g6a-be lights but goes out in 3-4 min.
mine is pretty new about a 1year in halve to two years old. i light with lighter it lights burns great then acts like propane cutts out then burns low then cuts out kinda acts like propane pressure cuts out in the valve but i can relight 30seconds later same thing. i have checked stove it burns great. is it in the waterheater propane valve. need help pease i need a cheap fix layed off right now. thank you dave
Sep 20, 2012 | RTO Atwood Water Heater - 6 Gal LP
Intermitant failure of waterheater to turn on when demand is created, then at other times there's no problem. lately it fails to resond more than it works.
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 27, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
My Paloma 42PVN shuts down and shows code IL. The manual says it's Lime deposits. How do I remove these deposits. The unit has been running fine for over 1 year but now it only runs intermittently and...
You need a 5 gallon bucket and a small sump pump that connects to a garden hose. The hose connects to the inlet of the water heater and and then run a second hose from the hot water outlet into the bucket. Pour in about a gallon of white distilled vinegar. Turn the pump on and let the vinegar run through the heater for 15 minutes. Reverse the hoses and run another 15 minutes. reconnect the heater and test the water flow. You may need to repeat these steps several times to remove enough debris and buildup.
Installing a water softener treatment system will prevent the buildup from occurring so fast, if ever again.
Oct 15, 2010 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
I also a Paloma tankless water heater that is 2 years old. I am now getting an error code C7 76 also. Is this something I can take care of, or should I call a plumber to address?
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support .
If this helps, please indicate so.
Mike//jzklipper
Nov 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma tank less water heater flashes code C4 13 and we have no hot water?how to fix it?
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 16, 2009 | Rheem Paloma Tankless Water Heaters...
I have a paloma tankless water heater about 3 years old model PTG-74PVN and it works for 2 minutes and shuts off with error code C4 and 13 flashing. (City water pressure is fine)Can anyone help? Thanks...
Nov 03, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Tankless water heater (Paloma) Has C2 11 error
I had this problem with the C2 11 error code. My unit is 1.5 years old. I called Paloma and they emailed me an 11 page document to clean the burners. I am not an HVAC but I got the feeling that's who the instructions were for. Very difficult but you can do it if you're handy. You basically take apart 1/2 the unit, be carfull not to lose any screws and label all the little brackets that come off. It took me 2-3 hours to get to the burners. I used a can of air (for keyboards-electronics) to blow on the burners and clear any build up. After putting it back together (carefull to make sure the 3 gas tubes make a seal when re-installed) the unit works. I did this today so I'm not sure the unit will still work in a week/month. I am dreading having to do this every year to keep the unit running.
Sep 28, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a 2 year old paloma tankles heater i get a c4 76
Make sure the wire connecting the thermostat to the unit is 18 gauge solid copper thermostat wire
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
76 C8 error display on control board
Call Paloma and they will send you a new circuit board. We had the same problem. Our heater is a little over 2 years old. They said the error "76" is a circuit board issue where the tank is not communicating properly with the remote. The other solution they told us was to disconnect the remote and just let the heater run on the default.
Jul 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
98 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
