Question about Kitchen Ranges
Hello, the cook top of my stove was cleaned today and now one burner(the left front, I think) is clicking intermittently as happens when the stove is turned on initially.
  • 2,374 Answers
Try lighting that burner then turn it off.
Posted on May 07, 2017
Testimonial: "The advice/answer was very helpful. This site works. Thanks."
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
Aug 02, 2009 | Kitchen Ranges
Back burner caught fire
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Jun 17, 2009 | Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove help
I'd like to know, too. Thank you for your help.
Jul 27, 2008 | Tappan TGF320 Gas Kitchen Range
Frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Jun 26, 2008 | Kitchen Ranges
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
I was cleaning stove top and all of a sudden the electrode on thr front right burner started clicking and the middle burner in the rear clicking also and will not stop.
IWAS TOLD TO DRY IT OUT WITH MY VACUUM BLOWER WHICH DID NOT WORK THEN HE GAVE ME PLAN B.WHICH WAS TO COOK BREAKFAST EVEN THOUGH IT WAS STILL CLICKING AND THE HEAT FROM THE STOVE WOULD PROBABLY DRY IT OUT......IT DID AND IT STOP CLICKING!
May 26, 2008 | GE Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
