I have a BassCube 851 - Audio Players & Recorders
Ducati 851 wiring diagram?
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Ducati despair not, for a mere $10 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day.
Workshop Manual Ducati 888 Superbike Strada 888 Sport Production Omologato...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Ducati 851 Superbike Kit
the official tips and tricks thread Speedzilla Motorcycle Message Forums
Apr 02, 2013 | 1988 Ducati 851 Strada (Tricolore)
Tip
Manual
Here a copy of the manual in PDF format:
ftp://www.rodinaudio.com/Phoenix%20Gold%20Mobile%20Audio/Manuals/Processors/BassCube%20Manual.pdf
on Aug 02, 2008 | Phoenix Gold Tantrum BASSCUBE Car...
Hello, i'm looking for the code of my peugeot philips car radio
Code is 4331
Philips 22RC200/65S prod nr. FDO 401130193383 TOK 851 PHAPMF 10193383
Dec 17, 2012 | Car Audio & Video
No speaker output from Basscube 8s
Yes. Check your connections that you are using from your preamp/processor or receiver to the Basscube to confirm that any adjustments I'll give you instructions for will go to the correct output. There are 2 ways that signal can be connected to the Basscube, your inquiry does not describe which you are using; either speaker level or line level. Line level is the easiest as it uses only one cable so I'll assume that is what you've used.
The following instructions I'll provide you with will presume that you are using a digitally controlled receiver or preamp/processor with an LED or LCD display and remote.
On the preamp/processor or receiver, navigate to your speaker setup menu and adjust the frequency output of any bass management system it may have to a full range signal. This may be a setting labeled for speaker size for example, choose "large." Or, if it has just a crossover setting, increase that to it's highest value.
Then go to the rear panel of your of your Basscube. Adjust the crossover to about 120Hz.
Return to your preamp/processor or receiver. Navigate to your speaker level control on the speaker setup menu. Increase this level to a matching value for each channel until you can hear your Newton speakers.
May 16, 2012 | Cambridge Soundworks BassCube 8S Speaker
Basscube 15 hums only in "Auto" mode?
There is a guy on ebay (edwards electronics) that can repair this amp for around 150.00
Feb 20, 2012 | Cambridge Soundworks BassCube 12 Speaker
Basscube 10 dead...need zener and resistor help
The zener diodes are 1N4774, I believe they are one watt. Try 3 watt metal oxide for the resistors. You might as well replace the 6800uF 63 volt main filter capacitors and the 220uF 50 volt capacitors while you're at it. Half the time the heat that cooked your other parts takes them out as well.
Jul 17, 2009 | Cambridge Soundworks BassCube 12 Speaker
Basscube remote knob wire
sloth...
funny seeing this question posted here... I worked at Phoenix Gold for 4 years, and I can help you with your problem.
when the BassCUBE was designed, the engineers didnt realize that a standard phone cable is what we call a "flipped cable", where if you were to lay the cable flat without any twists in it, on one end the connector would be tab up, and the other end would be tab down. on a standard RJ11 plug (the phone plug), the telephone requires that the pinout is as follows:
#1 - Black
#2 - Red
#3 - Green
#4 - Yellow
But the BassCUBE needs a non-flipped cable, which are hard as heck to find... so I will give you the quick easy fix.
You need a 2-line (4-wire) telephone cable that has a black, a red, a green, and a yellow wire in side it, and you will need 4 crimp caps or other way to splice the wires back together. You then need to cut the wire in half, and carefully seperate and strip each wire on each piece of the cable. Call one piece "Part A", and the other piece "Part B". Then you need to splice the cable back together as below.
Part A Part B
Black ------------------> Yellow
Red --------------------> Green
Green -----------------> Red
Yellow ----------------> Black
Once you have done this, and your SURE that your splice is good (not shorted out), then go ahead and plug your modified cable into the BassCUBE and its remote control, power it up, and you should be good to go.
Nov 04, 2008 | Phoenix Gold Tantrum BASSCUBE Car...
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
53 people viewed this question
 Grubhead
Grubhead
