Question about The Computers & Internet
Accidentally touched buttons on monitor screen black explain buttons
Can't get monitor to work again unless I can do so using the 5 buttons .. or is there another fix ?
  • 473 Answers
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Posted on Sep 14, 2005
SOURCE: AOC LM729 17" LCD Monitor Screen goes black
first take off the speakers. you'll see the cable for the speaker. in this slot u can put a screwdriver an pulloff the silver front carefully. then you will see the screws at the top and the buttom. but its better to take off the stand before removing the front. there are 4 screws behind a cover right near the stand. without removing the stand u wont be able to remove the display/electronic
Posted on Jun 11, 2008
  • 19 Answers
SOURCE: Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Posted on May 16, 2009
  • 822 Answers
SOURCE: Computer monitor screen stays black
check secondary power supply budged capacitors and apply fresh solder. check also lamps connectors.
Posted on Jun 02, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Corporate Computer
Posted on Jul 30, 2009
What do I do to get a screen that is frozen on a hp2010i monitor it is asking for language but the cursor on my mouse wont go to the selection
HP Monitor Problem - YouTube
? 1:35
Jul 22, 2009 - Uploaded by 7TimeToShine7
So I can use the monitor like I am using now but when themonitor goes to sleep I ... I tried it with a different computer and the monitor was able to re-find the ... How to fix or troubleshoot a blank or black screen not powering up ...
Monitor message" Power Button Lockout" - HP Support Forum > ... > Video/Touch
Feb 2, 2011 - 10 posts
Solved: New HP 23" monitor - HP 2310m Accidentally held down the power button too long; now I can't get the monitor to turn completely off. ... How can I turn the monitoroff completely and clear the message "Power Button ..... 8) ยท HP PCs - Error Messages Display on a Black Screen during Startup or Boot ...
OSD Lockout on my desktop monitor - HP Support Forum ... > ... > Boot
Dec 25, 2010 - 9 posts
If that doesn't work then go into the monitor's menu and do a factory reset. ... it looks like those button get stuck and doesnt work anymore so this is the ... OSD lockout prevents the OSD menu from opening on the screen when ...
Jan 03, 2016 | HP 2010i Black 20" Widescreen LCD Monitor...
I accidentally hit the auto-adjustment button on my monitor. Now, the an inch of of my screen from left to right is black. Not even my mouse can go into the black space.
Did you try hitting the Auto adjust again to possibly shut it off. Quite often the buttons work as off and on buttons such as the Caps Lock. you hit it and it's on. You hit it again. It's off. If you hit the Auto adjust it might shut off and re-adjust your screen to the original setting you had. ....don't forget that you made other adjustments to compensate for the mal adjustment that will need to be fixxed. good luck.
Dec 22, 2014 | HP W2072a 20in. LED-Backlit LCD Monitor,...
Cant log into windows. screen black
If you have a function button try holding it down and pressing F2, possibly the screen has been accidentally switched off.
Apr 15, 2013 | HP Compaq Presario V2000 Notebook
Black screen on computer monitor
Here is the link for the E151FPb monitor manual.
Since you email your question you have access to get this manual and print it. The manual shows the Auto set button, the contrast control button and a monitor reset feature.
Unfortunately you have to do each of these blind. Follow the instruction given, push buttons smartly, wait a few seconds for any action to take place, then follow the next instruction.
Good luck.
Feb 01, 2010 | Computers & Internet
Screen works but dosent respond to any touching?
Check that the "touch screen lock" is not engaged. To avoid accidental activation of the touchscreen, many models use some kind of "security" so that after a fixed time, the touchscreen will stop responding unless you (e.g.) click an unlock button. Verify this on the user manual.
Nov 05, 2009 | Samsung Instinct Cell Phone
My ipod screen is enlarged
Your iPod Touch is not broken! You accidentally invoked one of the accessibility features which zooms the screen. This happens when you double-tap the screen with three fingers simultaneously. To undo it, double-tap again and drag three fingers up or down.
You can turn this feature off by going to Settings > General > Accessibility > Zoom.
Oct 20, 2009 | Apple iPhone Smartphone
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Monitor goes black
Hi...there, It's could be 2 things...either your cables inside is lose or one of your caps is leaking fluid from the inverter. Turn off the power and open the back casing to check all the cables are secured. Good luck!
Aug 07, 2008 | Westinghouse L1975NW Monitor
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Computers & Internet Logo
19 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
