Question about The Office Equipment & Supplies
I try to get into the machine but unable to. I press 107 and appeared this message System Sp, Printer Sp. I press System Sp but can not get in the machine. What is the problem?
5 Suggested Answers
SOURCE: Unable to Print
won"t print make noise , check for paper jam ok, ink ok display routine maintenance check user guide
Posted on Sep 20, 2008
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Posted on May 04, 2009
richroth
  • 9472 Answers
SOURCE: Ricoh Aficio 2045 PCL 6:
It's not the PCU (photo CONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Posted on Jan 30, 2011
  • 199 Answers
SOURCE: I am getting the message
1. Get the unit into the "Support Menu" by following the steps below according with the product,
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release the "OK" button
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. If the error is still there, or reoccurs replace the unit.
VOTE ME IF YOU LIKE THIS SOLUTION
Posted on Aug 12, 2011
Reset code for sc546 on ricoh copier
1. Yellow cancel
2. 107 (on blue keypad)
3. Red cancel (press and hold down until machine beeps)
4. Menu will appear on screen - select System/Copy SP
5. 7807# (on blue keypad)
6. Select execute on screen
7. Select exit on screen
8. Switch machine off and on again.
If the error re-appears then you have a failing part and will need to replace it. Common parts to replace are Hot Roller, Thermister or Thermostat.
Jul 15, 2016 | Ricoh Office Equipment & Supplies
Reset memory for ricoh sp5100
Not exist memory reset,only Memory Clear.Before execute Memory clear print out all SMC data list.
Enter in SP mode : press Clear(yellow key) press 107 press and keep hold more 3 seconds Stop/Clear(red) key select SP mode select SP 5801 or select using the arrows up/down SP memory clear.Press the OK and execute,when the program has ended normally,the message COMPLETED is displayed.If the program has ended abnormally an error message is displayed.Turn the main switch OFF and ON.Adjust the printer and scanner registration and magnification.Refer to the SMC lists and enter any values that differ from factory settings.Adjust the standard white level,initialize the TD sensor.It is a work from 4-5 hours,good luck.
Feb 08, 2013 | Ricoh Office Equipment & Supplies
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
MPC2500 my machines are saying INDEPENDENT TONER.
This happened when you take of the toner bottle, replace a new bottle and that put it again the bottle that as bean there before.
You can enter in SP mode and disable this messages.
Try this:
press yellow key
press 107 in the key pad
Old the red key at least 3 sec.
After that press "COPY SP"
Press on the key pad 5051001 and than #.
Press the OFF button and than press OK on the bottom.
Exit all the way out and reset your machine by turning OFF and turn ON.
Hope that helps.
See you
Apr 23, 2011 | Ricoh Office Equipment & Supplies
What is rhe meaning of sc542 from ricoh mp6000?
That is a fuser temperature failure.
What you can try is this.
Press Clear all ( yellow ) then 107 , then press and hold the stop button.
You will see a screen that says Copy or System SP.
Press Copy SP, once that screen changes, power the machine off then back on.
If that doesnt work then enter ares 5 Modes, and scroll to Clear SC codes and execute that, then power the machine off and on.
If that doesnt work then the thermistors and overheat thermostats will most likely need to be replaced. It is more likely that entering SP mode will clear it.
Feb 22, 2011 | Office Equipment & Supplies
How do I clear Fuser oil low message on Ricoh Aficio 1232C after refilling fuser oil bottle
At the machine. Press in this order. Clear all ( yellow button) then 107, then press and hold the pink stop button until the screen changes. You will see some icons that say Copy SP, Sytem SP.
Select Copy SP, if thats not available select System SP.
You will see several buttons. Select sp 7 Data Log, Then scroll to page 804 and select that. Then scroll to item 11. That is where you will select to clear the fuser oil count and reset it.
Jan 28, 2011 | Ricoh Aficio 1232C Color Copier
Error sc 551
try to SP reset then lets see what code appears
SP RESET
press Clear Mode 2x
107
press Clear Mode for 5 sec or until Copy Sp appears
Press Copy Sp
Exit
Turn off machine then on after 5 to 10 sec.
Aug 23, 2010 | Ricoh Aficio 450 Copier
Lanier ld 435 color print code sc548
re install fixing unit and do the sc reset. press clear mode 2x 107 press clear/stop until COPY SP appears press Copy Sp then exit, turn off machine then on after 5 to 10 seconds
Aug 23, 2010 | Lanier Office Equipment & Supplies
Gestetner DSM627 Service Code Problem
These SC errors are related to the Hard disk.
Re - enter SP mode: Clear, 107 and press and hold Stop button for 3 secs.
Enter SP 5832-008 and press #,(Mail Tx data) to initialize the HDD. Then switch off and on the machine.
If still with error, replace the HDD.
Attention not to change any others SP modes - very sensitive settings!
Good luck and please rate me, thanks.
Feb 18, 2009 | Gestetner DSm627sp All-In-One Laser...
Machine display an error code sc 500
YOU MUST RESET machin by: press clear mode key(yellow)---enter 107 by keyboard----press clear/stop key (red) for4 seconds--- turn off machin and on
Dec 22, 2007 | Gestetner DSm615 Digital Imaging System
21 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
