Question about Kenmore Dishwashers
Kenmore 655.13759 will not come on. will only run test pattern, and will cycle drain pump when "cancel" or "pots and Pans" selected on keypad. have replaced control board, no change.
yalmer
  • 549 Answers
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Posted on Feb 16, 2008
bigg t
  • 640 Answers
SOURCE: Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Posted on Aug 06, 2008
  • 530 Answers
SOURCE: Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Posted on Jan 06, 2009
  • 530 Answers
SOURCE: unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
Posted on May 10, 2010
mastatech
  • 478 Answers
SOURCE: Kenmore Dishwasher Model# 665.13592K600 stopped
Try resetting breaker if there is no off/on lightswitch type. If continues its the control board a really basic repair skills needed.
Posted on Jul 12, 2010
Why does our dishwasher drain when large items are put through?
if your question is why does the washer drain first when pots and pans mode is selected? the answer is mfg. have realized that most everyone prerinses there pots and pans first , this makes a lot of water drips in bottom of washer this affects the volume of new water it can allow to enter , so they have made it pump out first for a \few minutes when first turned on in that mode ,it should fill after that and wash normally , also this is why its important to use soap dispensers and not just toss the soap in as it may get rinsed away in first few minutes and not get to wash cycle
Feb 16, 2016 | Dishwashers
Model 664.15732000. The Normal Wash light on control panel will not light up however the Pots and Pans light will. I ran the cancel/drain cycle and re-tried. See my video. Could if be the fuse in the
Hi there, can you put it through the pots and pans wash cycle , see if it works with that first ?
also the drainage pipe might be blocked making the normal cycles unusable.
you might need to get in a plumber or somebody that can unblock a pipe.
Hope this helps .
Dec 29, 2012 | Dishwashers
I have a kenmore Ultra wash dishwasher Model # 665-16022400 apprx 7 yrs old-everything was working fine till xmas of 2011-then when you pushed smart wash then try to press start nothing happens-also you...
Well, Larry, it sounds as if you've tried just about everything.... except replacing the control console (with keypad), and if everything else is okay, then that is PROBABLY your problem.
Jan 09, 2012 | Kenmore Dishwashers
Unit will not run. cannot enter diagnostic mode.
May 10, 2010 | Dishwashers
My whirpool quiet wash plus will not completey drain
lets see here you want at least ten bucks to just help me w/ my diswasher problem but if gee i figured it out all by myself i get squat thanks but no thanks.
Aug 28, 2009 | Dishwashers
My kenmore dishwasher, model 15822, just stopped working. The quick rinse light is blinking. The only other buttons that work are the pots & pans light which blinks when pushed, and the cancel button...
These are known to develop sticky switch contact pads. They stick in the contacted position and stifle the panel. Sometimes heat can be applied with a hair dryer to release them and make the unit function again. This is more than likely a temporary fix. New panels are available for about $165 to $200.
Jul 16, 2009 | Kenmore Dishwashers
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
Stuck on wash cycle
Aug 05, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
