Question about FrancisFrancis! X1 Espresso Machine
Have a 7 year old Francis Francis X1. Is making an alarming noise (pump?) and won't take any water in. Easy & cheap to repair or should I be getting another one?
  • 9 Answers
I have fixed a few of these, it may simply be that you boiler is scaled up. If it's really bad (and sounds like it is) you will need to dismantle the boiler. This is actually very simple but only if you are the kind of person that is confident with taking things to bits. If it's an aluminium boiler version then the chances are the boiler will be seriously corroded and beyond repair. I do have a spare boiler for this model if required. If you decide not to attempt repair and are in the UK I would be interested in purchasing your machine for parts. Let me know if you need help with dismantling it and I'll try to talk you through.
Richard
Posted on Jul 30, 2009
  • 54 Answers
Yes Bay new one
Posted on Jul 25, 2009
I have a Francis Francis x1 machine, but when i want to make an espresso shot, and turns on the espresso button, the steamer spour out boiling water (not steam, and not while turned on). Does anyone k
Don't know how your controls are set, but you have two switches on the front and a knob on the right. The switch for the steamer (the right hand switch) should be off. The knob on the right should be turned clockwise to turn in off. Then no water or steam should come out of the steamer wand. If it does, the seal on the knob inside the machine is broken. It can be repaired but only if you're handy with a screwdriver (make sure if you take it apart you disconnect it from the mains).
Jun 24, 2014 | FrancisFrancis! Coffee Makers & Espresso...
"francis francis" x1 blocked - Fix Suggestions?
You can tell if the pump is working by the noise it makes. Mine got blocked with scale and I took it apart and cleaned out the boiler. It's possible; the boiler is bolted together with standard bolts (metric size). If you've got the interest the Francis Francis is easy to service; you will find a way into each part of it and clean it, and if you do it will work like new.
Jun 22, 2014 | FrancisFrancis! Coffee Makers & Espresso...
My francis francis x1 has started running very slowly, it takes about 2x longer for the shot to finish coming out than it used to.
Hi
You might need a new pump or relief valve on the pressure end of the pump. There is a hose the goes back to the water tank in the back from the relief valve. See if water is going back into the tank when you are brewing?
Dec 31, 2009 | FrancisFrancis! X1 - Stainless Steel...
Í have a francis francis X1 for 3 years now.
Hi
There are 4 nuts that hold the chrome head on. They are either 7mm or 8mm nuts. Loosen then and the head should twist out.
Nov 23, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 pump replacement.
http://www.craystone.com/francis/francisfrancisfaq.html
for spares Espresso Parts, Tel: 0870 3851531
Oct 20, 2009 | FrancisFrancis! X1 - Stainless Steel...
No steam
You may have a clog in one of the hoses. Otherwise pump may be clogged. Or faulty heater. Is it hot?
Aug 28, 2009 | FrancisFrancis! X1 Espresso Machine
Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 Espresso Machine Logo
625 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
