Question about The Computers & Internet
Can you help me fixed this error code SC863-06. it is the Returned, bad sector in Hard drive. I want to know the how to format the HDD.
    Top Expert:
  • The Master
  • 45,659 Answers
Go to system manager to reformat the hard drive
make sure that you know what you are doing because formatting a hard drive means that everything ( operating system, files folders) --everything is lost for good
better is you find the disc repair section in the manager section and use that and not the format section or return to a previous date before the problem and reinstall to that date
Posted on May 07, 2017
Model RDXV59DTKB2 HDD/VCR. On HDD playback it has started,after varying periods of time, to freeze the picture. It can only be restarted by using FF and then Play.
You should be talking to Toshiba support, It could be a bad hard drive having trouble with sectors lost and access. Same as in computers. The way to eliminate hard drive errors is to do a low level format but that just maps the bad sectors into the bad sector table. When the drive starts to fail like this then it is time to not try and fix it as it will continue on this path as the errors migrate across the media disc but to replace it. Low level format is just putting off the failure until the errors become too many to deal with. Probably a Seagate drive- you don't buy them you only rent them for a small time. I stopped buying then at all. Made in China is all you need to know.
Mar 12, 2016 | Toshiba Televison & Video
Why does error code 8001002f appear when formatting disk ?
Remove and reinstall it, if it still gives the error code it means the hard drive is bad or going bad. That error code means the Ps3 can't read the hdd or certain sectors of the hdd. Best to always use a new hdd when replacing the hdd in your Ps3 anyways. I'd a hdd dies andyou haven't backed it up you lose aall your game saves and anything that is not tired to a psn account.
Jun 27, 2014 | Sony Playstation 3 (PS3) Console
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
Remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Jun 03, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Im getting an error code 08-0E89-0000 how do i fix this I had Toshiba A305-6844 after removing all the partition from the HDD using Recovery Disk I get Error #08-0E89-0000 while recreating the partitions...
I had the same message, replaced the hard drive, still got the same error code, took the hard drive back to best buy and they game me a new one, put it in and got the same message again...
Jul 02, 2008 | Computers & Internet
Hdd bad sectore problim
bad sectors are not fixable as far as hard drives go.
you mmight find software that claims ti fix bad sectors but the claim is false as they only temporarily overwrite the sectors and unmark the bad and remark to good but the problem remains to be the sectors are bad.
The best thing to do is to replace the hard drive with a good used one or a new one.
Sorry but as a technician I know what bad sectors are and what happens when you get them.
Jan 22, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Harddisk Bad sector & not detecting
Hi, If your partitioning and/or formatting program is already reporting "bad sectors", then your best bet is to replace the hard drive. The mere presence of bad sectors indicates drive problem which in the normal course of time/usage would increase and eventually make the drive inoperable. Using such a drive as your "C" and/or to contain mission critical files may not be to your advantage. Hope this be of some idea/help. Good luck and kind regards.
Sep 28, 2007 | Seagate ST3250820A 250 GB EIDE Hard Drive
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Computers & Internet Logo
42 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
