Question about Garden
Black eagle will not start
New chainsaw
My Eagle ****** Chain Saw Model No 600016L doesnt start and I do not have a manual. Any advice would be appreciated. I've chanaged the spark plug!
if it has been sitting for over 30 day or has gas that over 30 days you may need carb repair. the gas goes bad if you dont put any fuel and ethanol stabalizer and will gum up your carb.
Sep 21, 2011 | Garden
I am looking for a new carburettor diapham for a Talon Eagle Classic Brushcutter. Could you tell me where one is available. Thank You
Yep - just discovered today you have to buy a complete carburettor...from HUSQVARNA, the new owners of Talon. For what it's worth. the 25cc part number is 522211101, cost:$65.00
Mar 06, 2011 | Garden
I was given a Pioneer chainsaw. It wont start. Has spark good compresion. I pull the carb. off and clean it. It was dirty. Put back together and it still wouldnt run. Can you help me? I dont have the jet...
get a product called START. its made by gold eagle. it is an amazing product. i have used it many times. in their promo they add it to a chainsaw with old gas in it. 2 or 3 pulls and it started right up. i have cleaned carbs and they wont start, add this and they start. the longer it runs the cleaner things get and the better it runs.
the standard settings for the low jet is 1 1/4 turns out. the hi jet is 1 3/4 turns out ,that should allow you to start the saw. Once the saw is started adjust the low jet first, try to get the highest rpm at idle then turn it back out 1/8 of a turn . the hi speed jet is adjusted by holding the throtle wide open find the highest rpm,then back it out until you hear the rpm drop
Jan 30, 2011 | Garden
What color are the wires on a 1992 eagle talon to hook up my new stereo.for example.what color is the speaker wires,left front r front left rear right rear.thank you
Here you go.
1990-92 Eagle Talon Stereo Wiring Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Trigger White/Black Antenna Left Rear Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6 1/2" Side Panels Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
Jan 16, 2011 | 1992 Eagle Talon
Hi. Alf here I have a Victa Commando 50 year anniversary model which won't run unless i keep pushing the primer, when i stop pushing it the mower cut's out.Any help would appreciated.Alf
Hi, there is a new product called "start" from glod eagle. i have uses it many times and i am sold on it. i have used it to fix problems like yours. here is a link so you can read about it yourself.
http://www.goldeagle.com/brands/start_your_engines/default.aspx
Dec 28, 2010 | Garden
1993 Eagle Talon Tsi starts rough then dies off, bad timing?
First thing you can do to try a simple fix is replace each spark plug, check each plug for signs of fuel/air mixture
if your plug is black is rich, if ur plug is white is lean.
in this case repost your findings. in the mean time if they look golden or light brown, replace them and make sure they are gapped to ur level of psi you are running.
you can find the gap specs for how much boost you are running on most DSM websites or by searching.
Mar 27, 2009 | 1993 Eagle Talon
1994 Eagle Summit 2.4 l
you better doble check the timing marks and make sure they are right
May 30, 2008 | 1993 Eagle Summit
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
