Question about Cell Phones
Where do I insert simcard in my dgtec 8 tablet
Can I use my dgtec 8" tablet as a mobile phone by inserting a simcard
yes sure can just need to have charge on the sim...
May 07, 2017 | Cell Phones
Why does my tablet say simcard not registered
please contact the provider of your data service and check if SIM card has been activated.
Sep 03, 2014 | Samsung Galaxy Tab Tablet PC
How i can put simcard show vedeo
1) you state the problem is with an Apple iPad 32gb Wifi Tablet. You will be unable to put a sim card in as this is not the 3G / 4G version.
2) Refer to the original product documentation.
3) Have you searched the manufacture website? There are online user guides on apple.com.
4) Use a small needle and press it in to the hole on the sim card slot. remove, insert your simcard and insert in to the ipad.
Jun 08, 2014 | Apple iPad 32 GB WiFi Tablet PC
I cannot open the back to fit my simcard
There is no SIM card slot on the Tablet, you have to purchase a separate and compatible 3G adaptor to put the SIM card in.
You insert this into the USB slot and then program the Tablet to use it, with the correct suppliers details.
Mar 18, 2014 | Kocaso M1050
How to install sim card
For most of the phone,sim card will be install at the back of your mobile phone. These are the steps on how to: 1. Turn off your mobile phone. 2. Remove the back case gently. 3. Remove the battery as well. 4. Theres instruction at the back of your phone on where to place the simcard and on how to insert it. 5. Make sure you properly inserted the sim card so you wont recieve offline mode error. 6. Plug back the battery. 7. Return the back cover. 8. Turn on your phone,then your good to go. remember that there are some phones wherein the simcard slot is on the side part of the phone. for this kind of phones,all you have to do is just lift the cover of the simcard slot then slowly insert the sim properly then turn on the phone and your good to go.
Dec 05, 2011 | Samsung Cell Phones
Give me formate code for samsung C5212
list of samsung codes for u
Quote:
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong
network SIM and insert a half of it,(pic2501)
so it won't ask for
network password and shows "Insert SIM" message.(pic sam25020)
Now put the battery ,and switch the phone on .(phone shows "InsertSIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone isstill asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable
networklock By typing: #7465625*638*00000000#(hash 7465625 star 638 star8zeros hash)
Phone is unlocked (check with *#7465625#)
For Model:
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type*#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# andhit the Call button. Turn off and insert another Simcard. Turn on. The code is00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) untilphone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter#0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Youwill get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
d500 - #*7337# - ( but not in the newer software versions )
update 04/02/07
1. If you have changed your phone password, change your password back to thedefault 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, thenSIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone islocked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will rebootthe phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization"or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier getsswitched back on)
10. Completed. You have now unlocked your phone.
tested on e900 and d900 phones - may work on similar models but not sure
ps this will work with your new sim but if you try anither sim not used in thatphone bofore it will need code doing again
Apr 03, 2011 | Cycling
I have inserted my telstra sim card but I cannot connect to the internet... do I need to do anything??
i just brought my samsung galaxy s and i have a telstra nextG simcard in it and it wont let me connect to the internet i can make and recive calls,txts etc please help
Jan 22, 2011 | Samsung Galaxy Tab Tablet PC
PUK and PIN code for a Samsung SGH-A117
Samsung D500
Switch phone on without sim and enter :-
#*7337#
if it does not work then you need a direct unlock in a shop
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another Simcard. Turn on. The code is 00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
*2767*3855#
*2767*2878#
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
Jan 19, 2009 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
