Question about The Computers & Internet
The mag on my 93r17fv is verry lose some times it is hard to feed. can it be fixed?
How to remove virus from computer
First try with any bootable antivirus scanning if not solved , backup ur hard drive and format and reinstall ur os or tr recovery
Sep 05, 2016 | Computers & Internet
How do I fix a pneumatic finish nailer that won't feed nails from the magazine
Does the tool stop firing at about the same point on the magazine every time? It could be there's either some blockage that you can't see in the mag or, that the mag has worn down. If the latter is the case, replace the magazine frame.
Sep 20, 2014 | Tools & Hardware - Others
How do you replace the head gasket
with great difficultry, It is verry time consuming end verry costly to have it (Replaced)
Nov 27, 2012 | 2000 Kia Sportage
Passenger side at end of axle losse inside rotor is loose on bearing and flopping inside with wheel off will just a bearing fix this
most likely it will be just the bearing, unless someone has driven it this way for prolonged time in this case it might need other parts as well such as a new axel, or even a rotor. if it has been the case then the axel nut that holds the axel in the bearing has gotten so hot the chances of loosining it up will be verry slim and verry hard to remove, thus damaging the axel nut threads. if nit is this loose, I would expect to replace the bearing and the axel.
Dec 31, 2010 | 2001 Hyundai Accent
My xbox is hard wired to router, router feeds computer wirelessly, if playing on xbox & computer is turned on I lose connection to xbox live....please help
I'm not sure if there is a way to fix that. Since both the computer and the Xbox use the internet, there isn't enough for both of them to run at the same time. Sorry man.
Jul 09, 2010 | Microsoft Xbox 360 Console
My microwave quit working and I have only had it 10 months. The light comes on put nothen else works.
Magnetron tube. To check it you must only use an ohm meter to see if it has continuity. It is also a possibilty that your capacitor is open. If it is open then power will not be transferred from the high voltage transformer to the magnetron via that capacitor and that diode. Would it be the diode? hard to say.The diode should read in one direction only. If it does not then it is bad. I think it may be either a fuse mounted on the mag or the capacitor. Also make sure the mag is not grounded from one of its spades to mag body and it has continuity between the 2 spades . All items must be checked for continuity with one wire removed to prevent a back feed
Aug 04, 2009 | Emerson Microwave Ovens
My emac is verry slow
Hmm can be any number of things - how many programs do you run at the same time? Do you have lots of dahboard applications running? Is your hard disk severely fragmented? When is it verry slow?
Jul 05, 2009 | Adobe Computers & Internet
Mag Innovission LT716 / 700P
The order the plug wires go is from the top right side - pink /blue
The bottom side - blue /pink
Sep 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Computers & Internet Logo
41 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
