Question about HP Computers & Internet
HP DV4000 1long, 2 short beeps - HP Computers & Internet
    Master:
  • HP Master
  • 534 Answers
Probably video card failure.
https://support.hp.com/ca-en/document/c02222922
Posted on May 08, 2017
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Lots of beeps on startup of HP Pavilion DV6000 entertainment pc
Beep Codes
Beep signal Additional indicators Meaning
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Jul 07, 2012 | Computers & Internet
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
HP pavillion DV 2000 cant boot and with 1 long 2 short beep
I found some info on a forum, it says the 1 long and 2 short beeps is a problem with the graphics chip. You may need a replacement motherboard.
Check this post out
http://www.computing.net/answers/hardware/1-long-2-short-beeps-hp-laptop-/52894.html
Aug 16, 2010 | HP Pavilion dv6000z Notebook
I have an HP NetServer E800 when i power on it beeps 4 times then no signal on screen???
Code Beeps POST Routine Description
16h 1-2-2-3 BIOS ROM checksum
20h 1-3-1-1 Test DRAM refresh
22h 1-3-1-3 Test 8742 Keyboard Controller
2Ch 1-3-4-1 RAM failure on address line xxxx*
2Eh 1-3-4-3 RAM failure on data bits xxxx* of low byte of memory bus
46h 2-1-2-3 Check ROM copyright notice
58h 2-2-3-1 Test for unexpected interrupts
98h 1-2 Search for option ROMs. One long, two short beeps on checksum failure.
B4h 1 One short beep before boot
Jul 29, 2010 | HP NetServer E800
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Hp dv5020us notebook, one long beep followed by 2 short beeps
1 LONG 2 SHORT BEEPS MEANS DISPLAY ADAPTER PROBLEM ,LOCATE RESEAT OR REPLACE
Jan 06, 2009 | HP Pavilion dv5020us Notebook
Computer beeps when I try to start up
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
