Question about Mustang Garden
I have a TB mustang 42 and when I engage a the blades it is running rough like the blades are not full spinning if I disengage them the engine runs smooth
SOURCE: runs until clutch is disengaged
I have the same problem with mine, I have ascertianed that the seat is not the problem, I am starting to think it is the break safty switch . Mind will shutoff if you let out on the brake or try to engage the baldes.
Posted on May 01, 2010
  • 13 Answers
SOURCE: the engine start running rough when pto in engaged.
An air filter can look clean and not be. Remover the air filter and pre filter and try again. If engine smooths out, you need a new air filter.
Posted on May 12, 2010
  • 635 Answers
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Posted on Jun 14, 2011
  • 640 Answers
SOURCE: the 12.5 murray 38 in
The problem is in the carb. First try using some bottled fuel system cleaner at a heavier dose than for a car, but be aware that too much may damage the carb. Then run the fuel out and fill with fresh and try again. When you engage blades and it sputters try to throttle down until it runs smooth and then slowly bring engine back up to mowing speed. You should be able bring it up and mow. Run out the fuel tank. If unable to do this trick and get the fuel system cleaner through you will need to have the carb. taken apart and cleaned thoroughly.
Posted on Jul 07, 2011
  • 2239 Answers
SOURCE: blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Posted on Jun 24, 2012
42" Poulan rider blades wont disengage once they are engaged the blades spin constantly
These units are cable engaged. The cable or linkage sounds like it is malfunctioning. There should also be a brake on the spindle to stop the blades when disengaged. First check your cable and connections.
Jul 02, 2017 | Poulan Garden
Blades wont disengage completely
The lever has worn out....thus it is not locking up immediately when fully disengaged. You'll need to trace down the lever right down to the blade mechanism and then you'll notice a fork shaped part that shows signs of wear....very common on craftsman riding mowers.
Dec 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Cutting blades won't disengage
Check you blades to see if one is bent. Do this with the mower NOT RUNNING and the KEY OUT of THE IGNITION! Look under the deck to see if one is bent. This will cause the wobble. As far as no disengaging your electric clutch could be bad. The bearing could have seized up.
Apr 24, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine slows down with blades are engaged?
sounds like the blade spindles are binding, many have Zerk fittings to grease them. with belt disengaged try turning the pulleys they should turn easily and have no wobble in them. if either is wrong replace spindle and best to change in sets. this is the most common issue.
Apr 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Zts has no Power when Blades Engaged
check your blades to make sure that they are not hitting the deck,, this would cause the knocking sound
Aug 19, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
23 people viewed this question
Top Mustang Garden Experts
Dennis Key
Dennis Key
Randy Schumann
Randy Schumann
Paul Sikkema
Paul Sikkema
Are you a Mustang Garden Expert? Answer questions, earn points and help others
