I have an wireless infrared headphone. 33-280. When I plugg it in all I get is static. Please help
3 Suggested Answers
SOURCE: Wireless Headphone not working with my portable DVD player
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
Posted on May 19, 2008
  • 117 Answers
SOURCE: I have three sets of
This web sight Has nothing to do with selling products. I would suggest contacting the manufacture of your headPhones.
Posted on Jul 14, 2011
How do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Can Sienna Van wireless earphones be used in other Sienna vans?
The wireless car headphones I have seen use infrared light to transmit/receive.You should be able to use any infrared wireless headphones,especially if they are from the same model vehicle.
Sep 18, 2013 | Car Audio & Video
How do I connect wireless headphones to my sony kv34hs510
Are your headphones blutooth or infra-red? Is your Trinitron Blutooth or infrared enabled to allow you to listen to it thru your headphones? If so, there must be an on/off switch that would actuate the Blutooth or infrared meachanism on the Trinitron itself. Otherwise, you WON'T be able to hear sound.
Sep 19, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
.cutting out and static
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in your device is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Feb 20, 2011 | Hauppauge Wireless Headphones
My turtle beach has static like noies when i plug it in to my controler
THis problem is usually caused by an older controller because the jacks are loose and don't make a good connection with the talkback cable. Try a new controller to see if the problem is fixed. Also, try cleaning the connections on the talkback cable with some alcohol to remove any corrosion on the metal.
Nov 15, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
I have the pyle infrared headphones and I can not get them to connect with my pyle dvd player can you help.
you need to make sure the ir sensors on the tv are conected. to do this track down the plug from the tv that goes to the dvd make sure the audio cables on the tv are also connected to dvd and not just the video cable
Jun 10, 2009 | XO Vision Wireless Infrared Stereo...
Technical spec for plantronics C60 headset
Plantronics CS60
Type: Headphone
Acoustic Seal: Sealed/Closed/Sound Canceling
Headphone Frequency Response: Hz
Headphone Sensitivty: 14 dB/1mW dB/1mW
Wireless Technology: Infrared
Battery Time: 9 hours hours
Battery Type: Alkaline
Radio Frequency Range: 1.8GHz
Transmission Range: 100 m.
Compliant Standards: TCO '07
Jan 16, 2009 | Plantronics CS60 Professional Headset
Jul 02, 2007 | XO Vision Wireless Infrared Stereo...
 Grubhead
Grubhead
